Broken: 4165a57a6672 (blender2.8 HEAD)
Worked: 2.79a
The old particle emitter render visibility was replaced by duplicator visibility. EEVEE and Cycles use that yet workbench ignores it entirely.
Original file is the following. A basic plane with hair and non visible emitter:
Open the file, select the plane object and in the Object > Duplication panel disable "Display Duplicator".
The emitter should then be invisible in the viewport for workbench the same way it is for EEVEE and Cycles.
