Ubuntu Linux 64-bit,
Intel HD 4000 graphics, i7, 16 GB ram
Broken: blender-2.80-27de412ca8d-linux-glibc219-x86_64 (June 14 build)
Similar crash with past three days build-bot versions.
Worked: blender-2.80-dd67d703a74-linux-glibc219-x86_64 (June 10 build)
Crash on Startup
Attempt startup by executing blender. Eliminating userpref.blend doesn't solve problem.
Terminal output and blender.crash.txt are below.
blender.crash.txt:
Blender 2.80 (sub 17), Commit date: 2018-06-14 20:54, Hash 27de412ca8d
backtrace
./blender(BLI_system_backtrace+0x20) [0x19c78c0]
./blender() [0x1009c98]
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7fae53abc4b0]
./blender(BLI_mempool_alloc+0x1) [0x1987781]
./blender(DRW_pass_create+0x1c) [0x15d1dcc]
./blender(DRW_hair_init+0x15) [0x160ae05]
./blender(DRW_draw_render_loop_ex+0x14f) [0x15ceeef]
./blender(view3d_main_region_draw+0x68) [0x10e7cc8]
./blender(ED_region_do_draw+0x375) [0x12e4f05]
./blender(wm_draw_update+0x3d1) [0x100ea31]
./blender(WM_main+0x30) [0x100a970]
./blender(main+0x305) [0xfac015]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fae53aa7830]
./blender() [0x100698e]
Terminal output:
tm@tm-K55A:~$ cd '/home/tm/blender-2.80-27de412ca8d-linux-glibc219-x86_64'
tm@tm-K55A:~/blender-2.80-27de412ca8d-linux-glibc219-x86_64$ ./blender
Read prefs: /home/tm/.config/blender/2.80/config/userpref.blend
Received X11 Error:
error code: 178
request code: 154
minor code: 34
error text: GLXBadFBConfig
Received X11 Error:
error code: 178
request code: 154
minor code: 34
Received X11 Error:
error code: 178
request code: 154
minor code: 34
Received X11 Error:
error code: 8
request code: 154
minor code: 34
error text: BadMatch (invalid parameter attributes)
found bundled python: /home/tm/blender-2.80-27de412ca8d-linux-glibc219-x86_64/2.80/python
GPUTexture: texture create failedGPUTexture: texture create failedWriting: /tmp/blender.crash.txt
Segmentation fault (core dumped)
Today, July 3 the same crash occurs with the latest build bot build in Ubuntu and in Fedora 27. The concurrent Windows build works fine in Win 10 on this system.
