I can load Blender CVS normally. But if I exit it, then reload it without first rebooting my computer, it will cause my computer to freeze. It doesn't always freeze on the second loading but usually freezes on the third opening. Also I can do other things in between reopenings of blender and it will still usually freeze. All the types of freezes are sometimes different. Sometimes blender will just crash and not reload until a reboot. But most of the time the mouse along with everything else will freeze. A few times blender has frozen but using Alt+Tab I have been able to continue doing things, but re-clicking on blender freezes the computer again.
Running the program with GDB I got the following message:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1232828720 (LWP 4747)]
0xb6be6f5d in _nv000091gl () from /usr/lib/libGLcore.so.1
Operating System: Kubuntu 6.10
Memory: 256 MBs : 32 MBs used for onboard video card
Video Card: Nvidia Geforce2
Video Card Drivers: 1.0-8776
CVS Build Date: 31/12/2006 (Australia Date Format)
Processor: AMD AthlonXP 1800
Steps to reproduce:
1. load blender
2. quit
3. load blender
4. quit
5. load blender
Usually it will freeze here but it sometimes does it before, or after if you continue loading and quiting.
This program at version 2.42a Ubuntu Build, did not freeze my computer. However it used to sometimes come up with a message "Segmentation Fault" and not load blender anymore, if I tried the same steps as mentioned before.
Logged In: YES
user_id=2923
Hi,
you need to report the 2.42a bug to Ubuntu - it is almost certainly a XLib/driver bug which we can't do anything to fix. They won't look at anything you build yourself - so you need to report it against their official 2.42a build.
LetterRip
Logged In: YES
user_id=2923
Ton there is possibly some related information on this bug here...
http://www.nvnews.net/vbulletin/showthread.php?t=78887
found it via a search on "_nv000091gl () from /usr/lib/libGLcore.so.1"
Logged In: YES
user_id=5432
I made it crash again and got a backtrace this time if it helps;
(gdb) run
Starting program: /home/philip/Blender-CVS/install/linux2/blender
[Thread debugging using libthread_db enabled]
[New Thread -1226553648 (LWP 7861)]
Ignoring Xlib error: error code 166 request code 146
/home/philip/.blender/icons: No such file or directory
[Switching to Thread -1226553648 (LWP 7861)]
0xb74c7002 in _nv000101gl () from /usr/lib/libGLcore.so.1
(gdb) bat[Kcktrace
#0 0xb74c7002 in _nv000101gl () from /usr/lib/libGLcore.so.1
#1 0xbfd0926c in ?? ()
#2 0xbfd09ec0 in ?? ()
#3 0xb696d000 in ?? ()
#4 0xbfd090f8 in ?? ()
#5 0x08ba0438 in ?? ()
#6 0xb74c599e in _nv000101gl () from /usr/lib/libGLcore.so.1
#7 0xbfd08edc in ?? ()
#8 0xb696d000 in ?? ()
#9 0xbfd090f8 in ?? ()
#10 0x00000000 in ?? ()
