What happened to 3d window curve drawing since november?
Curve, metaball, nurb and text object drawing in 3d windows has degraded since november 2006.
Simply adding a bezier curve produces only two vertexes with control handles with no visible curve.
Selecting an extruded (beveled) curve "ghosts" a wireframe image to the screen (see images), similar "special effects" happens to metaballs, text and nurbes.
Earlier Blender builds up to november work fine.
Yes, I have an ATI card ;-)
Powerbook g4 ATI 9000M Ubuntu Edgy PPC (stock xorg radeon drivers, AIGLX)..
glxinfo:
name of display: :0.0
libGL warning: 3D driver claims to not support visual 0x4b
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_video_sync,
OpenGL vendor string: Tungsten Graphics, Inc.
OpenGL renderer string: Mesa DRI R200 20060602 AGP 4x TCL
OpenGL version string: 1.3 Mesa 6.5.1...
Inloggad: JA
user_id=3093
Update...
Odd thing, switching to to editmode and back on a closed curve or a font object somehow "restores" the 3d view.
This is a driver issue, but I'm sure there must be a workaround somewhere...
Where to look in the code?
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:30 AM
