Ubuntu 15.04 64 bit - Nvidia Geforce GT 320M
Broken: blender-2.80-53c63db2ee1-linux-glibc219-x86_64
Worked: (optional) night builds from some month ago
Blender 2.8 just don't open, it crashes at start with segmentation fault; here following I pasted the console output:
env@env-K50ID:~$ '/home/env/blender_download/blender-2.80-53c63db2ee1-linux-glibc219-x86_64/blender'
Received X11 Error:
error code: 8
request code: 154
minor code: 34
error text: BadMatch (invalid parameter attributes)
Received X11 Error:
error code: 2
request code: 154
minor code: 34
error text: BadValue (integer parameter out of range for operation)
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 8
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
Received X11 Error:
error code: 2
request code: 154
minor code: 34
found bundled python: /home/env/blender_download/blender-2.80-53c63db2ee1-linux-glibc219-x86_64/2.80/python
(2, 74, 0)
File "/home/env/blender_download/blender-2.80-53c63db2ee1-linux-glibc219-x86_64/2.80/scripts/modules/addon_utils.py", line 359, in enable
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_scene_3ds' has not been upgraded to 2.8, ignoring
(2, 79, 1)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_scene_fbx' has not been upgraded to 2.8, ignoring
(2, 74, 0)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_anim_bvh' has not been upgraded to 2.8, ignoring
(2, 74, 0)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_mesh_ply' has not been upgraded to 2.8, ignoring
(2, 78, 0)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_scene_obj' has not been upgraded to 2.8, ignoring
(2, 76, 0)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_scene_x3d' has not been upgraded to 2.8, ignoring
(2, 74, 0)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_mesh_stl' has not been upgraded to 2.8, ignoring
(2, 75, 0)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_mesh_uv_layout' has not been upgraded to 2.8, ignoring
(2, 57, 0)
raise Exception(f"Add-on '{module_name:s}' has not been upgraded to 2.8, ignoring")Exception: Add-on 'io_curve_svg' has not been upgraded to 2.8, ignoring
(2, 80, 0)
CUDA cuInit: Unknown error
GPUShader: compile error:
(0) : error C7011: implicit cast from "int" to "ivec2"
Writing: /tmp/blender.crash.txt
Errore di segmentazione ("segmentation fault")
Also attached is the blender.crash.txt{F3892895}
