Windows 10 64-bit, Intel Core i5-6500, Nvidia GTX 1050 Ti
Broken: 2.79b f4dc9f9d68b
When adding any shader to Holdout, object disappears on render with Transparent enabled. In rendered preview or render with Transparent checkbox disabled second shader is distinguishable.
Check two node setups with rendered viewport mode, then try to render them separately. You will see that the lower one makes image completely transparent.
