Blender 2.79 Latest Build CRASH
Windows 10 64bit , laptop with Intel HD Graphics 4600 and Nvidia Quadro 1100M
Broken: 2018-07-16 , HASH: 72d1fb99344
When doing operations on object level and try to Undo, blender crashes . I've seen that when doing object level operations . Mirror, moving, scaling etc when I try to undo blender crashes .
The error I get is
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF7A655FA7E
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Jul 30 2018, 10:23 AM
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
The Problem with this issue is that there are no precise steps to reproduce it . Sometimes it crashes after doing basic scale and translate then try to undo, and other times it crashes after I do lots of operations . That's why I've attached the error.txt to see what steps i've done until it crashed . And for .blend files, I get crashes after I edit the basic cube, but I think I've isolated one of my own .
When I try to do a boolean, with the small rectangle to do a difference. Then apply the boolean modifier. Then try to do an Ctrl+Z . Blender doesn't register the undo and sometimes it crashes .
I've tried in other way . Do the boolean with the difference, edit the cutter, apply the boolean. then do a ctrl+z and blender crashes .
Blender I'm using is synced on dropbox between 3 computers . On all the same behavior .
The Blender Version is :
version: 2.79 (sub 5), branch: master, commit date: 2018-07-16 13:58, hash: 72d1fb99344, type: Release
build date: 16/07/2018, 07:31
I've tested this on Blender from Steam (2.79b) and I don't get any crash .
Catalin (giakaama) changed the task status from Unknown Status to Unknown Status.Aug 2 2018, 11:50 AM
