Flipping matcaps in opengl render crashes blender 2.8
Windows 10 64-bit
blender-2.80-9b817bc1689
when you press the filp matcap button blender crashes
create a new file
then change the render engine to opengl
in the lighting select matcap
press flip matcap
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Aug 1 2018, 8:39 AM
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Hahaha, indeed… and we still need a .blend file to reproduce the issue, too ;)
You shouldn't need one.
  • Factory Start-up
  • Set OpenGL Render engine
  • goto the lighting panel (shown in the screenshot)
  • select MatCap
  • Flip
  • Crash
I've tried it on ubuntu and Windows and both crash
Bastien Montagne (mont29) raised the priority of this task from 30 to 50.
This is a 3DView-specific setting… should never be exposed in buttons window, @Campbell Barton (campbellbarton) this may be in your area? Will fix crash itself (just missing poll callback), but won't fix the usability/UI issue behind it.
