Normal map shading errors in OpenGL
Windows 10 x64
AMD Radeon R9390X - Graphics card
AMD FX-8320 - CPU
Broken: All Blender versions
Adding a normal map to a model breaks the shading of the object.
Press "M" to toggle (mute/unmute) the normal map in the file and watch the shading change in the 3D view window.
Here is a video I recorded showing the problem in more detail.
youtube link
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.EditedAug 20 2018, 11:20 AM
It's not clear to me what the bug is, muting the Normal Map node is supposed to change the shading. It is needed for converting the Tangent Space normal to a normal for shading, so if you skip that step the result will be wrong wrong.
The video shows a different .blend file so we can't test that. Can you attach the .blend file that has the bug and a render showing the wrong result it gives you?
This comment was removed by Jonas Pilo (ninthjake).
Sorry, my wording is bad. I know the shading is supposed to change but it looks like adding a normal map adds a layer of reflectivity to the model.
I cannot share the file I showed in the previous video but I put together a new file + video that much better shows the issue.
(Open in Blender 2.8)
And here is how it looks for me
This time I simply just added a blank image as the normal map and plugged it into the standard Principled BSDF in Eevee on a default unwrapped cube.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Aug 21 2018, 10:43 PM
This issue is the different color management settings in Cycles and Eevee. For Eevee / viewport you need to change the color space in the image editor to be Non-Color Data as well.
I've added it to the list of settings to unify in T54659.
