I made a basic scene with just one light and a bunch of cubes, to try out the defocus node filter.
I turned on the DofDist on the camera to point at the front of the cube I wanted to focus on. Also turned on "Do composite" in the render buttons.
Now on to the nodes editor.
If I turn off the "no z buffer" option in the Defocus filter node, it will then
show the fstop button. However, when I adjust the fstop value, after I release the mouse button (I adjust it by clicking down with the mouse, and moving leftward), after I releae the mouse button, the fstop button disappears, and the "no z buffer" button re-enables itself. I then cannot disable it again at all.
So the problem is I can't adjust the node's fstop value, it keeps turning off and switching back to "no z buffer" option, which I don't want.
Logged In: YES
user_id=103
I cannot redo this... We need more information:
- what OS you use, what gfx card?
- what build is this, is the build reliable? (get the official 2.43 RC from blender.org)
- can you verify if this is maybe a redraw error (move view around a bit with middlemouse)
- make a .blend file for us, there might be something else...
Logged In: YES
user_id=4923
Oh man, I am such an idiot, I'm sorry I should have given more info
This is on Windows XP pro with SP2, on a Pentium D (dual core) 3.4 ghz system, with an Intel 82945G display chipset.
The build is the official 2.43RC1 install.
It does seem to be redraw issue, since it flickers a lot. I will try it out on my other system, that has an nvidia card.
Logged In: YES
user_id=4923
you can cancel this bug, it was an error on my part, I did not connect the z buffer correctly
