"Save as render" option under IMAGE_OT_save_as RNA in key config doesn't work
Windows, GTX 1050ti
2.8, f074642b2cf
"Save as render" option is always on, doesn't matter if it is checked, unchecked or default (unchecked).
Also "Copy" option is on by default, despite visible as unchecked. I've also noticed, that when I set "Copy" to "unchecked" "Relative path" option appears when trying to save file (it's not available by default: off). Not sure if it's intentional.
  • switch into image viewer
  • do save as or shift + S: save as render will be checked
  • change "save as render" option inside key config for save as to disabled
  • repeat save as for image
  • "save as render" will still be enabled
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Sep 12 2018, 12:02 PM
Cannot confirm that, unless image is render result, in which case 'save as render' is enforced by default, when operator is invoked.
So no bug here, that’s just expected behavior.
