File Output node is missing "Save as render" option
Windows, GTX 1050ti
2.8, f074642b2cf
I'm not sure if this is intentional behavior, missing feature or a bug, but still reporting this, as it might be useful.
It seems like there's no option to bypass color management when saving non-exr files from compositor. Documentation states:
By default only renders are displayed and saved with the render view transformations applied. These are the Render Result and Viewer image data-blocks, and the files saved directly to a drive with the Render Animation operator.
In contrary to image "Save as" with "Save as render" option disabled File Output node assumes, that only linear data is "not a render". There's no way to export from compositor non-linear files like jpg or png that contain "non-color data" like normal maps, image masks, material masks, baked textures or intermediate beauty files with color management disabled. Saving files one by one for stills seems not to be workaround for animations...
Just see File Output node options, there's no "Save as render"
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.
Bastien Montagne (mont29) edited projects, added BF Blender; removed BF Blender: 2.8.
Sounds more like a TODO and/or known limitation, @Sergey Sharybin (sergey)? Also, do not see anything specific to 2.8, afaik 2.7 does not have that option either.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Sep 12 2018, 10:44 AM
Thanks for the report, but this is a known limitation. One day we would need to implement more proper color management and such for file output (including manual saving from the editor, render output, nodes...). For until then considering it a TODO.
Thank you! As usual I can help with testing.
If new color management will not get into 2.8, this will surely make it more flexible.
