Broken: ed7f6b511f81 (blender2.8 HEAD)
Worked: 2.79a
Meshes created with Python, and the mesh.from_pydata() function are "invisible" until we go in and out of edit mode.
The data seems valid though, since the object Dimensions is correct even when the mesh is invisible.
Run the following script in the Text editor. In 2.79 it works fine. In 2.8 you have to toggle in and out of edit mode to see the mesh.
Maybe the issue is only that the API changed. If that's the case we need to update the release notes.
import bpy
# Create mesh object
mesh = bpy.data.meshes.new("Malha")
obj = bpy.data.objects.new("Objeto", mesh)
if hasattr(bpy.context, "collection"):
# Blender 2.8
bpy.context.collection.objects.link(obj)
bpy.context.view_layer.objects.active = obj
obj.select_set('SELECT')
else:
# Blender 2.7x
bpy.context.scene.objects.link(obj)
bpy.context.scene.objects.active = obj
obj.select = True
verts = [(0.8, 0.2, 0.0), (0.5, 0.6, 0.0), (0.3, 0.3, 0.0)]
edges = [(0, 1), (1, 2), (2, 0)]
faces = []
#faces = [(0, 1, 2)]
mesh = obj.data
mesh.from_pydata(verts, edges, faces)
mesh.update()For a more interesting mesh use:
verts = [(0.7071067690849304, 0.7071067690849304, 0.0), (0.7071067690849304, -0.7071067690849304, 0.0), (-0.7071067690849304, 0.7071067690849304, 0.0), (-0.7071067690849304, -0.7071067690849304, 0.0), (0.8314696550369263, 0.5555701851844788, 0.0), (0.8314696550369263, -0.5555701851844788, 0.0), (-0.8314696550369263, 0.5555701851844788, 0.0), (-0.8314696550369263, -0.5555701851844788, 0.0), (0.9238795042037964, 0.3826834261417389, 0.0), (0.9238795042037964, -0.3826834261417389, 0.0), (-0.9238795042037964, 0.3826834261417389, 0.0), (-0.9238795042037964, -0.3826834261417389, 0.0), (0.9807852506637573, 0.19509035348892212, 0.0), (0.9807852506637573, -0.19509035348892212, 0.0), (-0.9807852506637573, 0.19509035348892212, 0.0), (-0.9807852506637573, -0.19509035348892212, 0.0), (0.19509197771549225, 0.9807849526405334, 0.0), (0.19509197771549225, -0.9807849526405334, 0.0), (-0.19509197771549225, 0.9807849526405334, 0.0), (-0.19509197771549225, -0.9807849526405334, 0.0), (0.3826850652694702, 0.9238788485527039, 0.0), (0.3826850652694702, -0.9238788485527039, 0.0), (-0.3826850652694702, 0.9238788485527039, 0.0), (-0.3826850652694702, -0.9238788485527039, 0.0), (0.5555717945098877, 0.8314685821533203, 0.0), (0.5555717945098877, -0.8314685821533203, 0.0), (-0.5555717945098877, 0.8314685821533203, 0.0), (-0.5555717945098877, -0.8314685821533203, 0.0), (0.19509197771549225, 1.2807848453521729, 0.0), (0.19509197771549225, -1.2807848453521729, 0.0), (-0.19509197771549225, 1.2807848453521729, 0.0), (-0.19509197771549225, -1.2807848453521729, 0.0), (1.280785322189331, 0.19509035348892212, 0.0), (1.280785322189331, -0.19509035348892212, 0.0), (-1.280785322189331, 0.19509035348892212, 0.0), (-1.280785322189331, -0.19509035348892212, 0.0), (0.3950919806957245, 1.2807848453521729, 0.0), (0.3950919806957245, -1.2807848453521729, 0.0), (-0.3950919806957245, 1.2807848453521729, 0.0), (-0.3950919806957245, -1.2807848453521729, 0.0), (1.280785322189331, 0.39509034156799316, 0.0), (1.280785322189331, -0.39509034156799316, 0.0), (-1.280785322189331, 0.39509034156799316, 0.0), (-1.280785322189331, -0.39509034156799316, 0.0), (0.0, 1.5807849168777466, 0.0), (0.0, -1.5807849168777466, 0.0), (1.5807852745056152, 0.0, 0.0), (-1.5807852745056152, 0.0, 0.0)] edges = [(0, 4), (1, 5), (2, 6), (3, 7), (4, 8), (5, 9), (6, 10), (7, 11), (8, 12), (9, 13), (10, 14), (11, 15), (16, 20), (17, 21), (18, 22), (19, 23), (20, 24), (21, 25), (22, 26), (23, 27), (0, 24), (1, 25), (2, 26), (3, 27), (16, 28), (17, 29), (18, 30), (19, 31), (12, 32), (13, 33), (14, 34), (15, 35), (28, 36), (29, 37), (30, 38), (31, 39), (32, 40), (33, 41), (34, 42), (35, 43), (36, 44), (37, 45), (38, 44), (39, 45), (40, 46), (41, 46), (42, 47), (43, 47)]
