Windows 10 64-bit
NVIDIA GeForce GTX 970
Broken: v2.79
Worked: Has not ever worked to my knowledge.
If using the fill bucket on an image with transparency, transparent pixels will be filled in if connected to a not-transparent pixel of similar color that is being filled.
Use the Fill tool in the UV/Image Editor to attempt to make the black ring in the packed image Circle.png a different color.
