Broken: 14e1dfda4e1
When joining two objects, both with a multires modifier, Blender immediately crashes.
Broken: 14e1dfda4e1
Only happens when the multires modifier actually has subdivisions.
To reproduce open the file and press CTRL + J.
multires_apply_smat(struct Depsgraph * depsgraph, Scene * scene, Object * ob, float (*)[3] smat) (/home/jacques/blender-git/blender/source/blender/blenkernel/intern/multires.c:2224) multiresModifier_prepare_join(struct Depsgraph * depsgraph, Scene * scene, Object * ob, Object * to_ob) (/home/jacques/blender-git/blender/source/blender/blenkernel/intern/multires.c:2288) join_mesh_single(Depsgraph * depsgraph, Main * bmain, Scene * scene, Object * ob_dst, Object * ob_src, float (*)[4] imat, MVert ** mvert_pp, MEdge ** medge_pp, MLoop ** mloop_pp, MPoly ** mpoly_pp, CustomData * vdata, CustomData * edata, CustomData * ldata, CustomData * pdata, int totvert, int totedge, int totloop, int totpoly, Key * key, Key * nkey, Material ** matar, int * matmap, int totcol, int * vertofs, int * edgeofs, int * loopofs, int * polyofs) (/home/jacques/blender-git/blender/source/blender/editors/mesh/meshtools.c:213) join_mesh_exec(bContext * C, wmOperator * op) (/home/jacques/blender-git/blender/source/blender/editors/mesh/meshtools.c:510) join_exec(bContext * C, wmOperator * op) (/home/jacques/blender-git/blender/source/blender/editors/object/object_add.c:2603) wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const _Bool poll_only, _Bool use_last_properties) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1330) wm_handler_operator_call(bContext * C, ListBase * handlers, wmEventHandler * handler, wmEvent * event, PointerRNA * properties) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2054) wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2356) wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2616) wm_event_do_handlers(bContext * C) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:3070) WM_main(bContext * C) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm.c:412) main(int argc, const char ** argv) (/home/jacques/blender-git/blender/source/creator/creator.c:525)
I won't try to fix it because it looks like this code will soon be replaced anyway because it still uses DerivedMesh. Tell me when I'm wrong.
Maybe @Sergey Sharybin (sergey) or @Brecht Van Lommel (brecht) can have a look at it as well?
The crash is fixed and joining uniformly scaled objects is also working now.
Still need to work on proper joining for non-uniformly scaled objects, but don't think it's THAT important, so for now it goes to a TODO list.
Thanks for the report!
