Scrollbars should make space for the invisible action zone in the corners
Closed, ResolvedPublicTO DO
In Blender 2.8, we can now drag and split the editors from any corner. For this reason, the corner action zone indicators are no longer necessary because this applies to all corners.
However, the problem is that the scrollbars were moved in to overlap the action zone. This means that it's impossible to use the zoom handles in the corners, because the action zones overlap:
In 2.7x, there was a bit of space for the action zone. We should reinstate that again:
William Reynish (billreynish) lowered the priority of this task from 90 to Normal.Nov 8 2018, 7:32 PM
William Reynish (billreynish) renamed this task from Scrollbars should make space for the invisible editor corner widget to Scrollbars should make space for the invisible action zone in the corners.Nov 8 2018, 7:35 PM
William Reynish (billreynish) changed the task status from Unknown Status to Resolved.Mar 7 2019, 9:47 PM
