With the old radio buttons at the top, it was possible to drag over them to change context. This no longer works with the tabs.
| Status | Subtype | Assigned | Task | ||
| Confirmed | TO DO | None | T56950 UI Paper Cuts (Parent Task) | ||
| Resolved | TO DO | William Reynish (billreynish) | T57753 Dragging over the Properties tabs should switch context as you drag down the list |
