Tooltips are showing "Shortcut" even there's none. I'd propose to not show it at all if shortcut is None. Especially because in some cases (like the one in the image below) RMB doesn't work, so it's not possible to assign a shortcut easily.
| Status | Subtype | Assigned | Task | ||
| Confirmed | TO DO | None | T56950 UI Paper Cuts (Parent Task) | ||
| Resolved | DESIGN | Campbell Barton (campbellbarton) | T57992 Tooltips: Hide Shortcut if None found |
