XP-PEN Deco 01 pressure sensitivity not working
Linux Manjaro KDE Kernel 4.19.2-1
Broken: 2.79 (sub 6) c66570f519f build date: 2018-11-23, 00:29:04
Pressure sensitivity with XP-PEN Deco 01 not working in blender. In GIMP and krita, the pressure sensitivity does work.
I use tablet driver from official xp-pen website:
https://www.xp-pen.com/download/index/cid/36.html
It's not working right after the application starts.
  1. Delete the cube
  2. Add UV Sphere
  3. Add subdivision surface modifier
  4. Apply subdivision surface modifier
  5. Change from object mode to sculpt mode
  6. Start sculpting with pen tablet
Also when use grease pencil
Thank you
Thank you @Brecht Van Lommel (brecht)... It's now working if I didn't run xp pen tablet driver from website. But if I run the driver from xp pen tablet driver (https://www.xp-pen.com/download/index/cid/36.html), the pressure sensitivity is not working
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Nov 26 2018, 11:55 AM
Can you attach the output of running this in the terminal?
xinput list --long
Brecht Van Lommel (brecht) changed the task status from Resolved to Unknown Status.Nov 26 2018, 12:09 PM
Here, it is.
I think this fix should work based on the xinput log, but let me know if it doesn't work in tomorrow's build.
