Exporters: Curve Modifier not applied when "apply modifiers" are selected
Operating system: Windows 10 x64
Broken: 2.80 26d5a3625ed
Worked: 2.79b
Tested with the collada, obj and fbx exporter, I have not tested all exporters and if this also affects other modifiers (the array modifier works for example).
Add a curve, add a curve modifier to an object, export with the apply modifiers option enabled.
I can't get it work with array modifier too...
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Dec 6 2018, 2:21 PM
Can confirm this is not working for curve-modifier-deformed objects.
(Array modifier seems to works fine though?, also checked Bevel, seems to be fine as well)
Reason being that
me = ob.to_mesh(depsgraph=bpy.context.depsgraph, apply_modifiers=True) seems to return undeformed mesh here?
see
@Bastien Montagne (mont29): want to have a look?
@Bastien Montagne (mont29): there is also T58856 (and I will merge this report into T58856 -- so this we be off of your desk... of course you could still claim that one if you think this is for you...)
Bastien Montagne (mont29) changed the task status from Duplicate to Unknown Status.Dec 7 2018, 3:35 PM
Reopening, merge was not a good idea, though related those two reports remains separated problems.
