Blender 2.8.0 beta crashes when applying Textures. (eevee & lookdev in cycles)
Operating system: Windows 10 version 1803
Graphics card: Intel HD Graphics 4000
Processor: Intel core i5 3230M
RAM: 8GB
Broken: 2.8.0 beta, 2018-11-30
Worked: 2.79, 2018*11-29 (cycles only)
Blender crashes when I try to add materials to a model (default cube in this case) both in eevee and cycles.
  • Based on the default startup, add a plane to below the cube,
  • Switch to shading workspace.
  • Use Ctrl+T to add the basic texture node setup (node wrangler addon),
  • add in an image texture, and blender immediately crashes.
Eevee
  • blender freezes a second after clicking the use nodes options in the materials tab and doesn't respond till a force close and reopen. this happens even in solid mode.
Cannot reproduce here (linux, 970m, 410.78 drivers)
Guess this is related to the HD Graphics 4000?
Do you have the latest GPU drivers?
Does this happen with any texture (or just a particular one -- in which case you should attach this particular texture)?
@Clément Foucault (fclem): does this ring a bell?
Cannot reproduce here (Windows 10, HD520, 23.20.16.5018 drivers)
@Philipp Oeser (lichtwerk) : I've tried with different textures and it still happens. one of my marble textures worked but blender crashed when I disconnected the node. would try recording my screen
here's a video. issue seems to happen now, when I disconnect the node. and its consistent.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.Dec 5 2018, 11:24 AM
@Franklyn Afeso (afeso): we still dont know if drivers are up to date? [which driver version are you using?]
Setting this to Normal priority since this is obviously crashing
I tried your steps in cycles and it crashed on step 2!
Windows 7; Intel HD graphics 4400
Blender 2.8 |2018-12-08 17:06| (beta)
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.May 23 2019, 3:15 AM
