Blender 2.8 with 2.7X input method shortcut inconsistencies
System Information:
CPU: Ryzen 5 2600
GPU: RX 570 4GB
OS: Windows 10 Home
Blender Version:
Broken: Blender 2.8 Beta 925380050d0 (December the 2nd 2018)
Short description of error:
With the Blender 2.7X input option selected, the "Select All Toggles" are unavailable to the user and are deactivated while it should be activated.
Exact steps for others to reproduce the error:
  1. Open Blender and in the user preferences under inputs set your input method as "Blender 2.7X".
  2. Navigate to the 3D viewport and test the A button to deselect and select all. This will behave the same as the default for Blender 2.8, not like Blender 2.79. The results expected are those seen in when "Select All Toggles" is enabled in the input method "Blender".
Alaska (Alaska) renamed this task from Blender 2.8 Shortcut inconsistencies to Blender 2.8 with 2.7X input method shortcut inconsistencies .Dec 3 2018, 12:40 AM
