Eevee does not show image texture for unwraped object
Operating system: Windows 10
Graphics card: nvidia 1060
Broken: 2.8, a205493426b, 2018-12-3
1.Add plane object
2.Create new material for it
3.Drop image in shader editor and connect with the color imput of the shader.
4.Unwrap object.
  1. No image shown in render mode for eevee after unwrap.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Dec 3 2018, 2:28 PM
Did you change the viewport display mode to LookDev or Rendered? In solid mode we don't show textures by default.
Yes, neither LookDev or Rendered mode shows the texture after unwrap, but it does before unwrape
Cannot reproduce using your repo steps.
Even though they are simple steps: could you provide your blendfile right before unwrapping (so everything to repo would just be unwrapping)?
It worked 2 or 3 days ago, now I have to reset the uv map and unwrap twice to get it work
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.Jan 9 2019, 9:56 PM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jan 23 2019, 12:23 PM
With that blend file, I can just switch to lookdev/rendered mode and the texture shows up as expected.
Is this still an issue for you with the latest blender beta?
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Mar 1 2019, 5:16 AM
Following bug tracker policy, closing report after 7 days due to insufficient information to investigate further. We can reopen the report if more information is provided.
