Graphical glitch in Edit Mode: Vertices have hair-like extrusions (not to be confused with normals)
Operating system: macOS High Sierra version: 10.13.6 (Macbook Pro 2015)
Graphics card: Intel Iris Graphics 6100
Broken: Blender-2.80-1b6a394d862 (release date: Dec. 4th, 00:11:08)
A persistent graphical glitch in Edit Mode where there are hair-like extensions extruding from the vertices. Becomes longer/shorter when increasing/decreasing Vertex size in User Preferences. To clarify these are not the Normal lines.
Simply open up most recent Blender 2.80 Beta build and go into edit mode. No other steps necessary.
Examples
Vertex size 4:
Vertex size 32:
Vlitz (Vlitz) updated the task description. (Show Details)Dec 4 2018, 6:35 PM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Dec 14 2018, 6:39 PM
Your test blender version is quite old, can you try a newer one from https://builder.blender.org/download/ ?
If that doesn't help, can you attach the output of "--debug-gpu" and try to run blender with "--debug-gpu-force-workarounds" and see if that helps.
Vlitz (Vlitz) added a comment.EditedDec 15 2018, 2:00 AM
{F5956880}At the time of posting, that was the latest version. I've been keeping up with the latest public builds, and didn't want to spam the same bug over and over. The problem unfortunately still exists. I've tried "--debug-gpu" and "--debug-gpu-force-workarounds" as requested in the latest build (blender-2.80-aca13040dac), and still the same thing persists. However, when running Blender through "--debug-gpu" in the terminal, an error message appears whenever I switch to Edit Mode in the Viewport. Not sure what it means as I don't really code, but I do suspect it has to do with the bug:
Warning: Pass : , Uniform 'viewportSize' not found!
Warning: Pass : , Uniform 'edgeScale' not found!
Also, I don't know if this will be helpful or not, but I've run the latest build in Windows 10 using Bootcamp and the problem wasn't there.
Sebastian Parborg (zeddb) raised the priority of this task from 30 to Normal.
Vlitz (Vlitz) changed the task status from Unknown Status to Resolved.Jan 24 2019, 5:16 AM
Just writing an update: it seems this particular bug has been fixed with the Jan. 24th release (7f77961f1c38). Will update if the bug pops up (hopefully not).
