FCurve modifier (generator) not updating correctly
Operating system: win 7 64bit
Graphics card: nvidia gtx980 + gtx780
Broken:
blender2.8, commit date: 2018-12-03 00:27, hash: a205493426b
Worked:
blender 2.79
even if I change the values in the curve modifier, the animation does not change
add cylinder
add single keyframe in z rotation
in graph editor select Z euler Rotation
add generator modifier
whatever value I insert in the coefficient for polynomial the animation does not change
the curve Z has an incorrect origin
the same procedure in blender 279 does not generate errors
I attach zip files with blend and jpg
https://www.dropbox.com/s/vyf6ee4b88jg8u4/rotation.zip?dl=0
fra are (afranx) updated the task description. (Show Details)
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 50.Dec 7 2018, 2:51 PM
I can reproduce this. The Z rotation speed of the cylinder stays the same when changing the generator settings.
@Brecht Van Lommel (brecht) the search function here is quite bad as I can only search for usernames and not names. So I can't find Joshua Leung.
Can confirm this is not updating immediately. Muting/Unmuting the (generator) modifier will make it work again...
Cannot confirm. curve is going through [0,0] here (which is expected behavior for a generator?)
Will have a quick look at code to see if I can find something regarding first issue...
@Sebastian Parborg (zeddb) : Joshua is @Joshua Leung (aligorith)
Philipp Oeser (lichtwerk) renamed this task from the curve modifier did not follow values to FCurve modifier (generator) not updating correctly.Dec 13 2018, 3:45 PM
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.May 27 2019, 12:31 PM
This seems to be fixed now (cannot reproduce anymore), closing.
@fra are (afranx): feel free to comment again or reopen if issues persist...
