Camera Location, keyframe Bug
Operating system: Win 10 64 bit
Graphics card: 2xGTX 1080 Ti
Broken:
2.80, 2018-12-03, a205493426b
When camera location keyframed beyond timeline(or sometimes in) can't change keyframed values from 1st keyframe.
Create camera, set view to camera, add keyframe, change position on timeline, move camera in location tab - its looking like view is still only outframe of camera is moving and changing visual od depth. After release for ex OY location it will back to value from first keyframe. If description will be not enough I can provide video.
Revisions and Commits
I can not reproduce this issue. All location values does not seem to reset to previous value (unless the timeline is changed).
Is this still a problem for you if you switch to solid mode? Perhaps it's a problem with the rendered view.
However, I still have a hard time to reproduce this issue on my side (I'm on linux and built blender from git).
I'm trying to reproduce this issue with the default blender cube scene and I'm having no luck with that.
It would be really helpful if you could create a minimal blend file that have the issue and upload it here.
Here is a file - try to change OY and keyframe it while in view to camera
I can reproduce the issue on my end with that file, thanks!
Have you tried any newer blender versions? If I open up your scene and duplicate the camera and set that one as the active camera, it does not have this problem.
I'm beginning to suspect that this issue has been solved in never 2.8 builds. But files created with older builds are still bugged.
Video I sent was from a20549342 version from 2 days ago
and file I sent was created in be91d4ef9 version that is from yesterday
Does the problem still happen if you copy the camera and set the copy as the active scene camera?
Yes, it behave in same way. But if I "go out" of camera it start working properly.
Now I deleted this copied camera and again select old camera as active and now it looks like it is working properly.
According to angavrilov on IRC, this seem to be a depsgraph issue:
angavrilov | DarkDefender: right, after a brief look it seems something fishy may be happening with the AnimData->recalc flag - it's probably related to COW and depsgraph, so need to discuss with hackerman-
angavrilov | DarkDefender: basically, it seems if that flag is set on the non-COW instance, it is never cleaned up and forces animation to be re-evaluated every time
angavrilov | DarkDefender: If I clear that stuck flag from that camera object in the debugger, the bug is fixed
@Alexander Gavrilov (angavrilov) , why not to talk here, huh ;)
I am a strong believer in theory that AnimData->recalc flag is to be forgotten, gone and never brought back. It is kind of conflicts with granularity nature of the new dependency graph.
This is also something, i believe, we've discussed with @Brecht Van Lommel (brecht) about IDs -- they shouldn't get recalc flags set nowadays.
i experience the same problem on keyframing bug. the only way to pass it is to edit it via graph editor
