Segmentation faults while trying to render with GPU and CPU hybrid rendering in Cycles
Operating system: Linux Mint 19
Graphics card: nVidia GTX 970
Broken:
Blender 2.8 Hash: 26d5a3625ed
While trying to render some scenes with Cycles, I have been getting a crash with segmentation fault as a reason while having GPU and CPU hybrid rendering active. In many cases the problem is solved by choosing CPU in the device type and then rendering.
Terminal message:
TIFFReadDirectory: Warning, Unknown field with tag 37724 (0x935c) encountered.
Writing: /tmp/28Jem_rebuild.crash.txt
Segmentation fault (core dumped)
Crash report:
Blender 2.80 (sub 35), Commit date: 2018-11-29 15:57, Hash 26d5a3625ed
Tool 'Select Box' not found for space 'IMAGE_EDITOR'. # Warning
backtrace
./blender(BLI_system_backtrace+0x1d) [0x1b807ad]
./blender() [0x114e679]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f5ff8f99f20]
./blender() [0x24d9447]
./blender() [0x2575196]
./blender(_ZN3ccl9CPUDevice13thread_renderERNS_10DeviceTaskE+0x14b8) [0x1eea478]
./blender(_ZN3ccl13TaskScheduler10thread_runEi+0x83) [0x2b368a3]
./blender(_ZN3ccl6thread3runEPv+0xe) [0x2b384de]
./blender() [0x63ad72f]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76db) [0x7f5ffa5446db]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x3f) [0x7f5ff907c88f]
System options have the GTX 970 and CPU as compute devices, Cycles has GPU rendering active. Sample file may have CPU selected.
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jan 4 2019, 4:32 PM
I sadly do not have a CPU+GPU combo setup to test this.
Could you try a newer build in the off chance that this has been solved?
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Jan 4 2019, 4:36 PM
This was a temporary issue in the first beta build, it's been fixed since then.
