Info window shows non-working code for setting scene units in 2.8
Operating system: MacOS High Sierra 10.13.6
Graphics card:
December 04, 00:11:08, 1b6a394d862, blender2.8
When setting the scene unit from the properties panel, the info window shows an equivalent line of python code that raises an error.
  1. Make sure you have a properties area, a python console and an info area open
  2. In the properties area, go to the scene tab and set the unit system of the scene to Metric
  3. Notice that the corresponding python line bpy.context.scene.system = 'METRIC' shows up in the info area
  4. Run the line from the previous step in the python console
  5. Notice that an AttribteError is raised (AttributeError: 'Scene' object has no attribute 'system')
  6. Also notice that the unit system can be set properly using bpy.context.scene.unit_settings.system = 'METRIC'
Revisions and Commits
Per (stuffmatic) renamed this task from Info window shows non-working code for setting scene units to Info window shows non-working code for setting scene units in 2.8.Dec 5 2018, 8:36 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.
Can confirm. The command shown in the Info Editor is not generated correctly when any of the unit settings is changed. Will take a look.
