Moving one object takes another object with it
Operating system: Windows 10
Graphics card: GTX 1070
Broken: 2.80 Beta, 2018-12-08
(example: 2.79b release)
I have a scene with 5 separate objects. Some objects, when placed into the plane (intersecting it) when sort of parent to the plane and then, when you try to drag the object (move it) it will take the plane with it, but there will be a slight lag as though the plane is resisting.
  1. Try to move the cube without moving the plane. Movement of plane may not be 1 for 1 with the cube and may be subtle.
  2. Create a new object, then try to move it. It will take the plane with it, this time 1 for 1 movement.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Dec 12 2018, 8:53 AM
Bastien Montagne (mont29) updated the task description. (Show Details)
You have proportional editing enabled (O shortcut)…
