Operating system:
Graphics card:
Broken:
(example: 2.79b release)
In Edit Mode when i want to Mesh curve circle segments make smooth with using modifier - subdivision surface , its not be in smooth toggle like 2.79 . Please can fix this bug . Thank you. Regards. Pierre
