See DxDiag at the bottom
Broken:
2.8
Date: 2018-11-30
Hash: 4c31bed6b46
When using "Face Selection Masking" during texture paint, if you go out of texture paint mode and select new faces then go back into texture paint mode, the program crashes to desktop.
- Create a cube in Blender 2.8 (Eevee)
- Create a material and a texture to paint on.
- In edit mode some faces and then switch to texture paint
- Select the face selection masking button and paint some faces.
- Go into edit mode and select new faces
- Go into texture paint mode and try and paint on the new faces.
- Program crashes.
Time of this report: 12/10/2018, 15:48:59
Machine name: DESKTOP-M40N7TG
Machine Id: {F730230B-5479-435A-956F-D509CBF91012}
Operating System: Windows 10 Home 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
Language: English (Regional Setting: English)
System Manufacturer: Razer
System Model: Blade Pro
BIOS: 2.00 (type: UEFI)
Processor: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz (8 CPUs), ~2.8GHz
Memory: 16384MB RAM
Available OS Memory: 16272MB RAM
Page File: 25505MB used, 8173MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCPMicrosoft Graphics Hybrid: Supported
DxDiag Version: 10.00.17134.0001 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 630
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_591B&SUBSYS_67581A58&REV_04
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8263 MB
Dedicated Memory: 128 MB
Shared Memory: 8135 MB
Current Mode: 1920 x 1080 (32 bit) (120Hz)
HDR Support: Not Supported
Display Topology: ExtendDisplay Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.638195,0.337414), Green(0.322766,0.610852), Blue(0.151867,0.048352), White Point(0.313977,0.329602)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO169D
Native Mode: 1920 x 1080(p) (120.150Hz)
Output Type: InternalMonitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported Driver Name: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd12umd64.dll
Driver File Version: 22.20.0016.4815 (English)
Driver Version: 22.20.16.4815 DDI Version: 12 Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1 Driver Model: WDDM 2.2
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: SupportedHybrid Graphics GPU: Integrated
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: N/A
Driver Attributes: Final Retail
Driver Date/Size: 9/25/2017 4:00:00 PM, 67234552 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-1A5B-11CF-276B-4847BFC2DB35}
Vendor ID: 0x8086
Device ID: 0x591B
SubSys ID: 0x67581A58
Revision ID: 0x0004
Driver Strong Name: oem33.inf:5f63e53499417f2d:iKBLD_w10_DS:22.20.16.4815:pci\ven_8086&dev_591b
Rank Of Driver: 00D12001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeVP8_VLD DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 3
MPO Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)
MPO Stretch: 5.000X - 0.334X
MPO Media Hints:
MPO Formats: YUY2,R16G16B16A16_FLOAT,R10G10B10A2_UNORM,R8G8B8A8_UNORM,B8G8R8A8_UNORM
PanelFitter Caps: RGB,YUV,BILINEAR,HIGH_FILTER,STRETCH_YUV,STRETCH_RGB,IMMEDIATE,HDR (MPO3)PanelFitter Stretch: 5.000X - 0.334X
Card name: NVIDIA GeForce GTX 1060
Manufacturer: NVIDIA
Chip type: GeForce GTX 1060
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1C20&SUBSYS_67581A58&REV_A1
Display Memory: 14187 MB
Dedicated Memory: 6052 MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
Color Primaries: Red(0.642102,0.346203), Green(0.329602,0.622570), Blue(0.145031,0.069836), White Point(0.313977,0.329602)
Monitor Model: Cintiq W1310
Monitor Id: WAC1042
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: HDMIMonitor Capabilities: HDR Not Supported
Advanced Color: Not Supported Driver Name: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvldumdx.dll
Driver File Version: 24.21.0013.9882 (English)
Driver Version: 24.21.13.9882 DDI Version: 12 Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1 Driver Model: WDDM 2.4
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driverHybrid Graphics GPU: Discrete
Catalog Attributes: Universal:False Declarative:False
Driver Date/Size: 7/29/2018 4:00:00 PM, 952696 bytes
WHQL Logo'd: n/a
Device Identifier: {D7B71E3E-5F60-11CF-725F-55471BC2D535}
Vendor ID: 0x10DE
Device ID: 0x1C20
Revision ID: 0x00A1
Driver Strong Name: oem29.inf:0f066de3593bc02e:Section034:24.21.13.9882:pci\ven_10de&dev_1c20&subsys_67581a58
Rank Of Driver: 00D10001
Video Accel:
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC DXVA2_ModeVP9_VLD_Profile0
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not SupportedPanelFitter Stretch: Not Supported
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0298&SUBSYS_1A586758&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.8245 (English)
WHQL Logo'd: n/a
Date and Size: 8/29/2017 12:00:00 AM, 5921768 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0 Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (Realtek USB2.0 MIC)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: USBAUDIO.sys
Driver Version: 10.00.17134.0001 (English)
Date and Size: 4/11/2018 15:33:46, 151552 bytes
Cap Flags: 0x0
Format Flags: 0x0
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Date and Size: 8/31/2017 22:14:05, 5921768 bytes
Cap Flags: 0x0
Format Flags: 0x0Video Capture Devices
Number of Devices: 2
FriendlyName: USB Camera
Category: Camera
SymbolicLink: \\?\usb#vid_1bcf&pid_2c98&mi_00#6&2621c75f&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Rotation: 0
Manufacturer: Microsoft
HardwareID: USB\VID_1BCF&PID_2C98&REV_0007&MI_00,USB\VID_1BCF&PID_2C98&MI_00
DriverDesc: USB Video Device
DriverProvider: Microsoft
DriverVersion: 10.0.17134.1
DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 6/21/2006 12:00:00 AM
Service: usbvideo
Class: Camera
DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
ProblemCode: No Problem
BusReportedDeviceDesc: USB Camera
Parent: USB\VID_1BCF&PID_2C98\5&26f14151&0&9
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: WdmCompanionFilter
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\ACPI,\Driver\usbccgp
ContainerCategory: n/a
SensorGroupID: n/a
MFT0: n/a
DMFT: n/a
DependentStillCapture: n/a
EnablePlatformDMFT: n/a
DMFTChain: n/aEnableDshowRedirection: n/a
FrameServerEnabled: n/a
ProfileIDs: n/a
Category: Camera
SymbolicLink: \\?\usb#vid_0bda&pid_5823&mi_00#7&18a88197&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Rotation: n/a
HardwareID: USB\VID_0BDA&PID_5823&REV_0105&MI_00,USB\VID_0BDA&PID_5823&MI_00
Service: usbvideo
Class: Camera
ContainerId: {63736D73-7835-7878-0000-001E3B3C4E46}
Parent: USB\VID_0BDA&PID_5823\M00005616
UpperFilters: n/a
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\usbccgp
SensorGroupID: n/a
MFT0: n/a
DMFT: n/a
ProfileIDs: n/aDirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/aVendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
FF Driver: n/a
Device Name: Razer Blade Pro
Attached: 1
Controller ID: 0x0Vendor/Product ID: 0x1532, 0x022F
FF Driver: n/a
Device Name: Controller (XBOX 360 For Windows)
Attached: 1
Controller ID: 0x0Vendor/Product ID: 0x045E, 0x028E
FF Driver: n/a
Attached: 1
FF Driver: n/a
Device Name: HIDI2C Device
Attached: 1
Controller ID: 0x0Vendor/Product ID: 0x0488, 0xD020
FF Driver: n/a
Device Name: Wacom Tablet
Attached: 1
Controller ID: 0x0Vendor/Product ID: 0x056A, 0x0325
FF Driver: n/a
Attached: 1
FF Driver: n/a
Attached: 1
FF Driver: n/a
Attached: 1
FF Driver: n/a
Device Name: Razer DeathAdder Chroma
Attached: 1
Controller ID: 0x0Vendor/Product ID: 0x1532, 0x0043
FF Driver: n/a
Attached: 1
FF Driver: n/a
Attached: 1
Controller ID: 0x0Vendor/Product ID: 0x056A, 0x0326
FF Driver: n/a
Attached: 1
FF Driver: n/a
Device Name: GlidePoint Generic HID Device
Attached: 1
FF Driver: n/a
Attached: 1
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x8086, 0xA12F |
| Matching Device ID: USB\ROOT_HUB30 |
| Service: USBHUB3 |
| Driver: USBHUB3.SYS, 8/2/2018 19:40:43, 566568 bytes |
+-+ USB Composite Device
| Vendor/Product ID: 0x1532, 0x022F | |||
| Matching Device ID: USB\COMPOSITE | |||
| Service: usbccgp | |||
| Driver: usbccgp.sys, 4/11/2018 15:33:52, 168864 bytes | |||
| +-+ USB Input Device | |||
| Matching Device ID: USB\Class_03&SubClass_01 | |||
| Service: HidUsb | |||
| Driver: hidusb.sys, 4/11/2018 15:33:52, 42496 bytes | |||
| Driver: hidclass.sys, 4/11/2018 15:33:52, 173568 bytes | |||
| Driver: hidparse.sys, 6/8/2018 01:01:36, 46080 bytes | |||
| +-+ HID Keyboard Device | |||
| Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD | |||
| Service: kbdhid | |||
| Driver: kbdhid.sys, 4/11/2018 15:33:52, 40448 bytes | |||
| Driver: kbdclass.sys, 4/11/2018 15:33:52, 63904 bytes | |||
| +-+ Razer Blade Pro | |||
| Matching Device ID: USB\VID_1532&PID_022F&MI_01 | |||
| Lower Filters: rzendpt | |||
| Driver: rzendpt.sys, 7/19/2017 06:16:36, 52240 bytes | |||
| Matching Device ID: HID\VID_1532&PID_022F&MI_01&Col01 | |||
| Upper Filters: rzudd | |||
| Driver: rzudd.sys, 7/19/2017 06:16:40, 205328 bytes | |||
| Matching Device ID: USB\Class_03 | |||
| Matching Device ID: HID\VID_1532&PID_022F&MI_02 | |||
| Service: mouhid | |||
| Driver: mouhid.sys, 4/11/2018 15:33:52, 33280 bytes | |||
| Driver: mouclass.sys, 4/11/2018 15:33:52, 56728 bytes | |||
| Vendor/Product ID: 0x1532, 0x0043 | |||
| +-+ Razer DeathAdder Chroma | |||
| Matching Device ID: HID\VID_1532&PID_0043&MI_00 | |||
| Matching Device ID: USB\VID_1532&PID_0043&MI_01 | |||
| Matching Device ID: HID\VID_1532&PID_0043&MI_02 | |||
+-+ Generic USB Hub
| Vendor/Product ID: 0x056A, 0x0327 | |||||
| Matching Device ID: USB\USB20_HUB | |||||
| Service: USBHUB3 | |||||
| Driver: USBHUB3.SYS, 8/2/2018 19:40:43, 566568 bytes | |||||
| +-+ Generic USB Hub | |||||
| Vendor/Product ID: 0x056A, 0x0324 | |||||
| +-+ USB Composite Device | |||||
| Vendor/Product ID: 0x056A, 0x0326 | |||||
| Matching Device ID: USB\COMPOSITE | |||||
| Service: usbccgp | |||||
| Driver: usbccgp.sys, 4/11/2018 15:33:52, 168864 bytes | |||||
| +-+ Wacom Tablet | |||||
| Location: 0000.0014.0000.001.006.002.000.000.000 | |||||
| Matching Device ID: USB\VID_056A&PID_0326&MI_01 | |||||
| Upper Filters: mshidkmdf | |||||
| Service: WacHidRouterPro | |||||
| Driver: wachidrouter.sys, 9/24/2018 08:08:42, 115672 bytes | |||||
| Driver: wdfcoinstaller01011.dll, 9/24/2018 08:08:42, 1804656 bytes | |||||
| +-+ HID-compliant mouse | |||||
| Matching Device ID: HID_DEVICE_SYSTEM_MOUSE | |||||
| Service: mouhid | |||||
| Driver: mouhid.sys, 4/11/2018 15:33:52, 33280 bytes | |||||
| Driver: mouclass.sys, 4/11/2018 15:33:52, 56728 bytes | |||||
| Vendor/Product ID: 0x056A, 0x0325 | |||||
| Matching Device ID: USB\VID_056A&PID_0325 | |||||
| +-+ HID-Compliant Mouse | |||||
| Matching Device ID: HID\VID_056A&PID_0325&Col01 | |||||
| Upper Filters: wacomrouterfilter | |||||
| Driver: wacomrouterfilter.sys, 9/24/2018 08:08:42, 17880 bytes | |||||
| Driver: wdfcoinstaller01009.dll, 12/11/2012 14:12:00, 1721576 bytes | |||||
Gameport Devices
PS/2 Devices
| Vendor/Product ID: 0x0488, 0x0000 |
| Service: mouhid |
| Vendor/Product ID: 0x0488, 0x0005 |
| Service: mouhid |
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 49.0 GB
Total Space: 231.1 GB
File System: NTFS
Model: SAMSUNG MZVLV256HCHP-00000 Drive: D:
Free Space: 1907.5 GB
Total Space: 1907.7 GB
File System: NTFS
Model: ST2000LM015-2E8174 Drive: G:
Free Space: 46.6 GB
Total Space: 133.1 GB
File System: FAT32
Model: n/a
System Devices
Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #7 - A116
Device ID: PCI\VEN_8086&DEV_A116&SUBSYS_67581A58&REV_F1\3&11583659&0&E6
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.17134.0254 (English), 8/8/2018 20:54:29, 375704 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123
Device ID: PCI\VEN_8086&DEV_A123&SUBSYS_67581A58&REV_31\3&11583659&0&FC
Driver: n/a Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_A12F&SUBSYS_67581A58&REV_31\3&11583659&0&A0
Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.17134.0001 (English), 4/11/2018 15:33:52, 434592 bytes Driver: C:\Windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.17134.0001 (English), 4/11/2018 15:33:52, 123576 bytes Name: Standard NVM Express Controller
Device ID: PCI\VEN_144D&DEV_A802&SUBSYS_A801144D&REV_01\4&85B917&0&00E8
Driver: C:\Windows\system32\DRIVERS\stornvme.sys, 10.00.17134.0081 (English), 5/20/2018 04:33:14, 105368 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #5 - A114
Device ID: PCI\VEN_8086&DEV_A114&SUBSYS_67581A58&REV_F1\3&11583659&0&E4
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.17134.0254 (English), 8/8/2018 20:54:29, 375704 bytes Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_A171&SUBSYS_67581A58&REV_31\3&11583659&0&FB
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.17134.0001 (English), 4/11/2018 15:33:45, 86016 bytes Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.17134.0001 (English), 4/11/2018 15:33:46, 98304 bytes Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.17134.0001 (English), 4/11/2018 15:33:46, 379392 bytes Name: Intel(R) Serial IO I2C Host Controller - A160
Device ID: PCI\VEN_8086&DEV_A160&SUBSYS_67581A58&REV_31\3&11583659&0&A8
Driver: C:\Windows\system32\DRIVERS\iaLPSS2_I2C.sys, 30.100.1725.0001 (English), 6/27/2017 23:55:24, 191648 bytes Name: NVIDIA GeForce GTX 1060
Device ID: PCI\VEN_10DE&DEV_1C20&SUBSYS_67581A58&REV_A1\4&242A17E7&0&0008
Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 24.21.0013.9882 (English), 8/1/2018 01:49:26, 474072 bytes Driver: C:\Windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/30/2018 11:14:43, 1520404 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\NvContainerSetup.exe, 1.00.0007.0000 (English), 8/1/2018 01:50:02, 4430704 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\NvCplSetupInt.exe, 1.00.0007.0000 (English), 8/1/2018 01:50:04, 101323040 bytes Driver: C:\Program Files\NVIDIA Corporation\license.txt, 7/30/2018 11:14:43, 27203 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 8/1/2018 01:49:40, 858400 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.9882 (English), 8/1/2018 01:50:08, 429016 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 7/30/2018 11:14:43, 78136 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.9882 (English), 8/1/2018 01:50:38, 525168 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.9882 (English), 8/1/2018 01:50:50, 934232 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\OpenCL32.dll, 2.02.0001.0000 (English), 8/1/2018 01:52:24, 458312 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\OpenCL64.dll, 2.02.0001.0000 (English), 8/1/2018 01:52:26, 553376 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvlddmkm.sys, 24.21.0013.9882 (English), 8/1/2018 01:50:46, 17211376 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nv-vk64.json, 7/30/2018 11:14:43, 669 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvcbl64.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:46, 1815104 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvd3dumx.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:16, 19329816 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvd3dumx_cfg.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:22, 19737224 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvdlistx.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:36, 194600 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvldumdx.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:18, 952696 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvoglv64.dll, 24.21.0013.9882 (English), 8/1/2018 01:51:06, 40143376 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvrtum64.dll, 8/1/2018 01:51:20, 19920240 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvwgf2umx.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:54, 34240064 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvwgf2umx_cfg.dll, 24.21.0013.9882 (English), 8/1/2018 01:50:02, 35228104 bytes Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0013.9882 (English), 8/1/2018 01:50:28, 1565048 bytes Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0013.9882 (English), 8/1/2018 01:50:44, 1420576 bytes Driver: C:\Windows\system32\NvIFROpenGL.dll, 24.21.0013.9882 (English), 8/1/2018 01:50:44, 628920 bytes Driver: C:\Windows\system32\nvEncMFTH264.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:46, 1349384 bytes Driver: C:\Windows\system32\nvEncMFThevc.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:56, 1358720 bytes Driver: C:\Windows\system32\nvEncodeAPI64.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:04, 816392 bytes Driver: C:\Windows\system32\nvapi64.dll, 24.21.0013.9882 (English), 8/1/2018 01:47:58, 4858224 bytes Driver: C:\Windows\system32\nvcompiler.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:56, 40346808 bytes Driver: C:\Windows\system32\nvcuda.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:02, 17756224 bytes Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.9882 (English), 8/1/2018 01:50:06, 4352880 bytes Driver: C:\Windows\system32\nvfatbinaryLoader.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:10, 1159120 bytes Driver: C:\Windows\system32\nvinfo.pb, 7/30/2018 11:14:43, 44271 bytes Driver: C:\Windows\system32\nvopencl.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:30, 31250184 bytes Driver: C:\Windows\system32\nvptxJitCompiler.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:42, 13728728 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nv-vk32.json, 7/30/2018 11:14:43, 669 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvd3dum.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:12, 15888128 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvd3dum_cfg.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:28, 16222152 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvdlist.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:34, 168960 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvldumd.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:16, 795104 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvoglv32.dll, 24.21.0013.9882 (English), 8/1/2018 01:50:56, 32401880 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvwgf2um.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:48, 28882080 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\nvwgf2um_cfg.dll, 24.21.0013.9882 (English), 8/1/2018 01:50:10, 29957520 bytes Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0013.9882 (English), 8/1/2018 01:50:26, 1218528 bytes Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0013.9882 (English), 8/1/2018 01:50:42, 1094128 bytes Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 24.21.0013.9882 (English), 8/1/2018 01:50:44, 518488 bytes Driver: C:\Windows\SysWow64\nvEncMFTH264.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:44, 1065688 bytes Driver: C:\Windows\SysWow64\nvEncMFThevc.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:50, 1071568 bytes Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:00, 654760 bytes Driver: C:\Windows\SysWow64\nvapi.dll, 24.21.0013.9882 (English), 8/1/2018 01:47:56, 4128280 bytes Driver: C:\Windows\SysWow64\nvcompiler.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:48, 35250008 bytes Driver: C:\Windows\SysWow64\nvcuda.dll, 24.21.0013.9882 (English), 8/1/2018 01:48:00, 15170808 bytes Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0013.9882 (English), 8/1/2018 01:50:04, 3769016 bytes Driver: C:\Windows\SysWow64\nvfatbinaryLoader.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:08, 906808 bytes Driver: C:\Windows\SysWow64\nvopencl.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:24, 25966552 bytes Driver: C:\Windows\SysWow64\nvptxJitCompiler.dll, 24.21.0013.9882 (English), 8/1/2018 01:49:38, 11273816 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\nvrzi.inf_amd64_15380d6d6af783ca\VulkanRT-Installer.exe, 1.01.0073.0000 (English), 8/1/2018 01:52:34, 1233288 bytes Driver: C:\Windows\system32\nvdispco6439882.dll, 2.00.0052.0004 (English), 8/1/2018 01:50:20, 2002448 bytes Driver: C:\Windows\system32\nvdispgenco6439882.dll, 2.00.0026.0002 (English), 8/1/2018 01:50:22, 1467920 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family PMC - A121
Device ID: PCI\VEN_8086&DEV_A121&SUBSYS_67581A58&REV_31\3&11583659&0&FA
Driver: n/a Name: Killer E2500 Gigabit Ethernet Controller
Device ID: PCI\VEN_1969&DEV_E0B1&SUBSYS_67581A58&REV_10\4&8819EEC&0&00E4
Driver: C:\Windows\system32\DRIVERS\e2xw10x64.sys, 9.00.0000.0046 (English), 10/30/2017 11:25:24, 165608 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family LPC Controller (HM175) - A152
Device ID: PCI\VEN_8086&DEV_A152&SUBSYS_67581A58&REV_31\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.17134.0001 (English), 4/11/2018 15:33:49, 18848 bytes Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901
Device ID: PCI\VEN_8086&DEV_1901&SUBSYS_67581A58&REV_05\3&11583659&0&08
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.17134.0254 (English), 8/8/2018 20:54:29, 375704 bytes Name: Intel(R) Serial IO UART Host Controller - A127
Device ID: PCI\VEN_8086&DEV_A127&SUBSYS_67581A58&REV_31\3&11583659&0&F0
Driver: C:\Windows\system32\DRIVERS\iaLPSS2_UART2.sys, 30.100.1725.0001 (English), 6/27/2017 23:55:26, 310944 bytes Name: Killer Wireless-n/a/ac 1535 Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_003E&SUBSYS_15351A56&REV_32\4&19CF7219&0&00E6
Driver: C:\Windows\system32\DRIVERS\Qcamain10x64.sys, 12.00.0000.0468 (English), 2/1/2018 11:55:34, 2335632 bytes Driver: C:\Windows\system32\DRIVERS\qca61x4_2_2.bin, 2/1/2018 07:46:24, 1085552 bytes Driver: C:\Windows\system32\DRIVERS\Data61x4_2_2.msc, 2/1/2018 07:46:24, 97202 bytes Driver: C:\Windows\system32\DRIVERS\eeprom_ar6320_3p0_NFA364xp.bin, 2/1/2018 07:46:24, 8124 bytes Driver: C:\Windows\system32\DRIVERS\eeprom_ar6320_3p0_NFA364xp_RV_0519.bin, 2/1/2018 07:46:24, 8124 bytes Driver: C:\Windows\system32\DRIVERS\eeprom_ar6320_3p0_NFA364xp_RV_0520.bin, 2/1/2018 07:46:24, 8124 bytes Driver: C:\Windows\system32\DRIVERS\eeprom_ar6320_3p0_NFA364xp_LE_1.bin, 2/1/2018 07:46:24, 8124 bytes Driver: C:\Windows\system32\DRIVERS\eeprom_ar6320_3p0_NFA364xp_LE_2.bin, 2/1/2018 07:46:24, 8124 bytes Driver: C:\Windows\system32\DRIVERS\QcomWlanSrvx64.exe, 1.00.0000.0001 (English), 2/1/2018 11:55:42, 227728 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #9 - A118
Device ID: PCI\VEN_8086&DEV_A118&SUBSYS_67581A58&REV_F1\3&11583659&0&E8
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.17134.0254 (English), 8/8/2018 20:54:29, 375704 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #1 - A110
Device ID: PCI\VEN_8086&DEV_A110&SUBSYS_67581A58&REV_F1\3&11583659&0&E0
Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.17134.0254 (English), 8/8/2018 20:54:29, 375704 bytes Name: Intel(R) HD Graphics 630
Device ID: PCI\VEN_8086&DEV_591B&SUBSYS_67581A58&REV_04\3&11583659&0&10
Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdkmd64.sys, 22.20.0016.4815 (English), 10/6/2017 00:51:42, 13259232 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd10iumd64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:24, 20196216 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd10idpp64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:24, 527208 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd11dxva64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:28, 68545816 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd12dxva64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:36, 68534264 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd12umd64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 13852088 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdumdim64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:46, 67234552 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdail64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 196608 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd12ext64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 51976 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxcmrt64.dll, 10/6/2017 00:51:50, 235720 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfx11cmrt64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:50, 235816 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdde64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 640488 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iga64.dll, 10/6/2017 00:51:22, 1928352 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igc64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:22, 23441752 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdmd64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:42, 4039408 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd10iumd32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:24, 15924056 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd10idpp32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:24, 501952 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd11dxva32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:26, 66986808 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd12dxva32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:32, 66978936 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd12umd32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 13154584 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdumdim32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:44, 65645784 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdail32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 171008 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdde32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 487336 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igd12ext32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 47176 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxcmrt32.dll, 10/6/2017 00:51:50, 200032 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfx11cmrt32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:50, 200640 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iga32.dll, 10/6/2017 00:51:22, 1614368 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igc32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:22, 19888984 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdmd32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:42, 3135056 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxs64.vp, 10/6/2017 00:51:50, 4578 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxo64.vp, 10/6/2017 00:51:50, 40343 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxc64.vp, 10/6/2017 00:51:50, 40316 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxg64.vp, 10/6/2017 00:51:50, 39658 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxo64_dev.vp, 10/6/2017 00:51:50, 40931 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxc64_dev.vp, 10/6/2017 00:51:50, 41296 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxg64_dev.vp, 10/6/2017 00:51:50, 39798 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxa64.vp, 10/6/2017 00:51:50, 1125 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\iglhxa64.cpa, 10/6/2017 00:51:50, 2813952 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\IntelCpHDCPSvc.exe, 22.20.0016.4815 (English), 10/6/2017 00:51:52, 572968 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\IntelCpHeciSvc.exe, 9.00.0018.0917 (English), 10/6/2017 00:51:52, 485928 bytes Driver: C:\Windows\system32\cp_resources.bin, 10/6/2017 00:51:18, 756652 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\difx64.exe, 1.04.0003.0000 (English), 10/6/2017 00:51:20, 158248 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxDH.dll, 6.15.0010.4815 (English), 10/6/2017 00:51:50, 995328 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 118264 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 127992 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxDI.dll, 6.15.0010.4815 (English), 10/6/2017 00:51:50, 427520 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 30208 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 29696 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxLHM.dll, 6.15.0010.4815 (English), 10/6/2017 00:51:50, 2083328 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 22528 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 22520 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxSDK.exe, 10/6/2017 00:51:50, 1137704 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 99328 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 107520 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxEM.exe, 6.15.0010.4815 (English), 10/6/2017 00:51:50, 550952 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 27648 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/6/2017 00:51:50, 27648 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\GfxUIEx.exe, 6.15.0010.4815 (English), 10/6/2017 00:51:20, 492584 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\Gfxv4_0.exe, 8.15.0010.4815 (English), 10/6/2017 00:51:20, 898600 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\Gfxv4_0.exe.config, 10/6/2017 00:51:20, 935 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\Gfxv2_0.exe, 8.15.0010.4815 (English), 10/6/2017 00:51:20, 892968 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\Gfxv2_0.exe.config, 10/6/2017 00:51:20, 895 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\GfxResources.dll, 8.15.0010.4815 (English), 10/6/2017 00:51:20, 5054456 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (English), 10/6/2017 00:51:54, 641024 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxCUIServicePS.dll, 10/6/2017 00:51:50, 382456 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxCUIService.exe, 6.15.0010.4815 (English), 10/6/2017 00:51:50, 398376 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxCPL.cpl, 10/6/2017 00:51:50, 276984 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxDTCM.dll, 6.15.0010.4815 (English), 10/6/2017 00:51:50, 205824 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxext.exe, 6.15.0010.4815 (English), 10/6/2017 00:51:50, 921640 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxexps.dll, 6.15.0010.3682 (English), 10/6/2017 00:51:50, 55232 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\ColorImageEnhancement.wmv, 10/6/2017 00:51:14, 375173 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\ImageStabilization.wmv, 10/6/2017 00:51:52, 403671 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\FilmModeDetection.wmv, 10/6/2017 00:51:20, 641530 bytes Driver: C:\Windows\system32\igfxCPL.cpl, 10/6/2017 00:51:50, 276984 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igfxexps32.dll, 6.15.0010.3682 (English), 10/6/2017 00:51:50, 52736 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\ig9icd64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:20, 15740928 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\ig9icd32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:20, 11877376 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igvk64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:52, 9008272 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igvk64.json, 10/6/2017 00:51:52, 137 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\VulkanRT-EULA.rtf, 10/6/2017 00:52:04, 1469 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\VulkanRT-Installer.exe, 1.00.0054.0001 (English), 10/6/2017 00:52:04, 963896 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igvk32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:50, 8286120 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igvk32.json, 10/6/2017 00:51:52, 137 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 10/6/2017 00:52:00, 1981 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 10/6/2017 00:52:02, 9788 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 10/6/2017 00:52:02, 32 bytes Driver: C:\Windows\SysWow64\Intel_OpenCL_ICD32.dll, 2.01.0000.0000 (English), 10/6/2017 00:51:52, 116736 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 7.05.0000.0550 (English), 10/6/2017 00:52:02, 395264 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 7.05.0000.0550 (English), 10/6/2017 00:52:00, 12495360 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 7.05.0000.0550 (English), 10/6/2017 00:51:58, 1350656 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 7.05.0000.0550 (English), 10/6/2017 00:51:58, 562688 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 10/6/2017 00:51:58, 1576512 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 10/6/2017 00:51:58, 383768 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 10/6/2017 00:51:58, 580972 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 10/6/2017 00:51:58, 1501328 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 10/6/2017 00:51:58, 375784 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 10/6/2017 00:51:58, 580692 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 10/6/2017 00:51:58, 1099508 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 10/6/2017 00:51:58, 323132 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 10/6/2017 00:51:58, 523480 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 7.05.0000.0550 (English), 10/6/2017 00:51:58, 2394624 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.05.0001.0000 (English), 10/6/2017 00:52:02, 7520768 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.05.0001.0000 (English), 10/6/2017 00:52:02, 6605312 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.05.0001.0000 (English), 10/6/2017 00:52:02, 6409216 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.03.2017.0316 (English), 10/6/2017 00:52:02, 381952 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.03.2017.0316 (English), 10/6/2017 00:52:02, 531968 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 10/6/2017 00:52:02, 355992 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 10/6/2017 00:51:58, 1147008 bytes Driver: C:\Windows\system32\Intel_OpenCL_ICD64.dll, 2.01.0000.0000 (English), 10/6/2017 00:51:52, 140288 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 7.05.0000.0550 (English), 10/6/2017 00:52:02, 489984 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 7.05.0000.0550 (English), 10/6/2017 00:52:00, 16561152 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 7.05.0000.0550 (English), 10/6/2017 00:51:58, 1733632 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 7.05.0000.0550 (English), 10/6/2017 00:51:58, 745984 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 10/6/2017 00:51:58, 1581060 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 10/6/2017 00:51:58, 415016 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 10/6/2017 00:51:58, 606420 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 10/6/2017 00:51:58, 1505424 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 10/6/2017 00:51:58, 398352 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 10/6/2017 00:51:58, 603780 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 10/6/2017 00:51:58, 1104280 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 10/6/2017 00:51:58, 343512 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 10/6/2017 00:51:58, 545368 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 7.05.0000.0550 (English), 10/6/2017 00:51:58, 2984448 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 3.05.0001.0000 (English), 10/6/2017 00:52:02, 7810048 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 3.05.0001.0000 (English), 10/6/2017 00:52:02, 7077888 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 3.05.0001.0000 (English), 10/6/2017 00:52:02, 6882816 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.03.2017.0316 (English), 10/6/2017 00:52:02, 489984 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.03.2017.0316 (English), 10/6/2017 00:52:02, 663552 bytes Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb_preview.dll, 4.02.2013.1002 (), 10/6/2017 00:52:02, 433816 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\IntelOpenCL32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:52, 404480 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdrcl32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:42, 5510648 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\common_clang32.dll, 4.03.0000.0000 (English), 10/6/2017 00:51:14, 33698816 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdfcl32.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 676344 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\IntelOpenCL64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:52, 529408 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdrcl64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:42, 6456320 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\common_clang64.dll, 4.03.0006.0626 (English), 10/6/2017 00:51:16, 44914176 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igdfcl64.dll, 22.20.0016.4815 (English), 10/6/2017 00:51:40, 720888 bytes Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:52, 10418920 bytes Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.17.0009.0015 (English), 10/6/2017 00:51:54, 5950464 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 2612168 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 2468864 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:58, 2479616 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 2624328 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_encrypt_32.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 2471176 bytes Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 10/6/2017 00:51:18, 1361159 bytes Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 10/6/2017 00:51:18, 1125 bytes Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 10/6/2017 00:51:20, 57143 bytes Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 10/6/2017 00:51:20, 78413 bytes Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 10/6/2017 00:51:58, 73221 bytes Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 10/6/2017 00:51:20, 79777 bytes Driver: C:\Program Files\Intel\Media SDK\vr360sdk32.dll, 10/6/2017 00:52:04, 616680 bytes Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:54, 11221640 bytes Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.17.0009.0015 (English), 10/6/2017 00:51:54, 6213632 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 3149864 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 2978304 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_64.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:58, 2992128 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 3174512 bytes Driver: C:\Program Files\Intel\Media SDK\mfx_mft_encrypt_64.dll, 7.17.0009.0015 (English), 10/6/2017 00:51:56, 2968592 bytes Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 10/6/2017 00:51:20, 1376256 bytes Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 10/6/2017 00:51:18, 1125 bytes Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 10/6/2017 00:51:20, 56359 bytes Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 10/6/2017 00:51:20, 13439 bytes Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 10/6/2017 00:51:58, 13095 bytes Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 10/6/2017 00:51:20, 13995 bytes Driver: C:\Program Files\Intel\Media SDK\vr360sdk64.dll, 10/6/2017 00:52:04, 615656 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\igxpco64.dll, 1.03.0025.0000 (English), 10/6/2017 00:51:52, 235008 bytes Driver: C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_ebf62e9f754a446a\DisplayAudiox64.cab, 10/6/2017 00:51:20, 612785 bytes Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_A13A&SUBSYS_67581A58&REV_31\3&11583659&0&B0
Driver: C:\Windows\system32\DRIVERS\TeeDriverW8x64.sys, 11.07.0000.1014 (English), 4/11/2017 03:35:44, 205432 bytes Name: Intel(R) Xeon(R) E3 - 1200 v6/7th Gen Intel(R) Core(TM) Host Bridge/DRAM Registers - 5910
Device ID: PCI\VEN_8086&DEV_5910&SUBSYS_67581A58&REV_05\3&11583659&0&00
Driver: n/a Name: Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_A103&SUBSYS_67581A58&REV_31\3&11583659&0&B8
Driver: C:\Windows\system32\DRIVERS\iaStorA.sys, 15.02.0016.1060 (English), 4/5/2017 18:11:00, 800256 bytes Name: Intel(R) 100 Series/C230 Series Chipset Family Thermal subsystem - A131
Device ID: PCI\VEN_8086&DEV_A131&SUBSYS_67581A58&REV_31\3&11583659&0&A2
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.17134.0001
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.17134.0001
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.17134.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.17134.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.17134.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.17134.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.17134.0112
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.17134.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.17134.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.17134.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.17134.0001
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.17134.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.17134.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.17134.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.17134.0407
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.17134.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.17134.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.17134.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.17134.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.17134.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.17134.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.17134.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.17134.0112
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.17134.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.17134.0001
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.17134.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.17134.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.17134.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.17134.0001
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.17134.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.17134.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.17134.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.17134.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.17134.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.17134.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.17134.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.17134.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.17134.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.17134.0001
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.17134.0407
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.17134.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.17134.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.17134.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.17134.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.17134.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.17134.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.17134.0320
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.17134.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.17134.0001
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.17134.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.17134.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.17134.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.17134.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.17134.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.17134.0001
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.17134.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.17134.0001
Audio Capture Sources:
Microphone (Realtek USB2.0 MIC),0x00200000,0,0,qcap.dll,10.00.17134.0001
Microphone (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.17134.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.17134.0407
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0407
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0407
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.17134.0001
WDM Streaming Capture Devices:
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
USB Camera,0x00200000,1,2,ksproxy.ax,10.00.17134.0001
Realtek USB2.0 MIC,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
USB Camera,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio 2nd output,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.17134.0001
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.17134.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.17134.0001
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,msvidctl.dll,6.05.17134.0001
Encrypt/Tag,0x00200000,0,0,,
PTFilter,0x00200000,0,0,,
XDS Codec,0x00200000,0,0,,
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.17134.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.17134.0001
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.17134.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.17.0009.0015
Intel® Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_64.dll, 7.17.0009.0015
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.17134.0407
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.17134.0001
Intel® Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_64.dll, 7.17.0009.0015
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.17134.0001
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.17134.0407
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.17134.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.17134.0112
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.17134.0001
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.17134.0001
Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.17134.0137
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.17134.0001Video Encoders:
Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.17.0009.0015
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264.dll, 24.21.0013.9882
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevc.dll, 24.21.0013.9882
Intel® Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 7.17.0009.0015
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.17134.0001
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.17134.0001
Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.17134.0191
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.17134.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.17134.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.17134.0112Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.17134.0001
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.17134.0407
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.17134.0001Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.17134.0376Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.17134.0081
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.17134.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.17134.0001
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.17134.0112
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.17134.0407
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.17134.0407
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.17134.0001
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.17134.0001
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.17134.0001
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.17134.0112
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.17134.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.17134.0407
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.17134.0407
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.17134.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.17134.0001
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.17134.0407
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.17134.0001Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.17134.0407
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.17134.0001
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.17134.0001
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.17134.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.17134.0112
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.17134.0001
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.17134.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.17134.0001
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.17134.0001Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.17134.0001 Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.17134.0137
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.17134.0407Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.17134.0407Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576 Enabled: Force throttling Allow half deinterlace Allow scaling Decode Power Usage: 100 Balanced Flags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 50 PowerFlags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 1348620606345868077, type 5
Event Name: RADAR_PRE_LEAK_64
Response: Not available
Cab Id: 0
Problem signature:
P1: blender.exe
P2: 2.8.0.0
P3: 10.0.17134.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 1547384751414034851, type 5
Cab Id: 0
Problem signature:
P1: UE4Editor.exe
P2: 4.21.1.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 1968683347884699139, type 5
Cab Id: 0
Problem signature:
P1: UnrealLightmass.exe
P2: 4.21.1.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER3 +++:
Fault bucket , type 0
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: CrazyBump.exe
P2: 1.2.0.1
P3: 55810480
P4: MSVCR71.dll
P5: 7.10.6030.0
P6: 44b451e8
P7: c0000005
P8: 000216d6
P9:
P10:
+++ WER4 +++:
Fault bucket 2141799339359439881, type 5
Event Name: MoBEX
Cab Id: 0
Problem signature:
P1: Microsoft.XboxGamingOverlay_1.16.1012.0_x64__8wekyb3d8bbwe
P2: praid:App
P3: 1.16.1804.1012
P4: 5bc7c851
P5: ucrtbase.dll
P6: 10.0.17134.319
P7: 40b70dec
P8: 000000000006cea8
P9: c0000409
P10: 0000000000000005
+++ WER5 +++:
Fault bucket 1609866141016002012, type 5
Event Name: StoreAgentScanForUpdatesFailure0
Cab Id: 0
Problem signature:
P1: Update;
P2: 8024402c
P3: 17134
P4: 407
P5: Windows.Desktop
P6:
P7:
P8:
P9:
P10:
+++ WER6 +++:
Event Name: LiveKernelEvent
Cab Id: 0
Problem signature:
P1: ab
P2: 1
P3: 9f0
P4: 0
P5: 35
P6: 10_0_17134
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: Update;
P2: 8024402c
P3: 17134
P4: 407
P5: Windows.Desktop
P6:
P7:
P8:
P9:
P10:
+++ WER8 +++:
Cab Id: 0
Problem signature:
P1: ab
P2: 1
P3: 9f0
P4: 0
P5: 35
P6: 10_0_17134
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER9 +++:
Fault bucket 1155540790886808120, type 5
Event Name: MoAppCrash
Cab Id: 0
Problem signature:
P1: InputApp_1000.17134.1.0_neutral_neutral_cw5n1h2txyewy
P2: praid:App
P3: 10.0.17134.191
P4: 5b49749a
P5: combase.dll
P6: 10.0.17134.112
P7: fad18dc5
P8: 8001010e
P9: 0000000000010de0
P10:
