principled volume bsdf a always a cube shape
Operating system: windows 10
Graphics card: nvidia geforce 1050
Broken: 2.8 64 bit date: 2018-12-13 hash: 7d4d9e9dbd3
(example: 2.79b release)
Short description of error When applying principled volume bsdf to a sphere mesh, either modeled from a cube or uv sphere, the "Fog" is always a cube. This is problematic for making say...a planet with a volumetric atmosphere.
Exact steps for others to reproduce the error make a uv sphere or take a cube, subdivide a few times and turn up smoothness all the way. Give it a volume bsdf shader or volume scatter shader
Related Objects
I have the same problem when I open the file. Not sure if that is a limitation or not.
