Crash when rendering in EEVEE
Operating system: Windows 10 Pro 10.0.16299 Build 16299
Graphics card: NVIDIA GeForce GTX 1070
Broken:
(example: 2.80, 9149e894210, blender2.8, 2018-12-16 23:25
Crashes when I try to render using EEVEE
  1. Working in 2.79b I saved a copy to open in 2.80.
  2. Open file in 2.80
  3. Set engine to EEVEE
  4. Specify output folder/file
  5. press Ctrl-F12 to render.
  6. Crash.
Repeated this twice. The second time, it rendered one frame, then crashed. Third time crashed right away.
HOWEVER, when I choose Render Animation from the drop down menu, it doesn't crash! I did this twice to confirm.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Dec 18 2018, 10:43 AM
No crash here.
(there are font objects present, and there has been a fix for these yesterday -- @Jack Schaberg (JaySchay) could you try again with the latest buildbot build?)
If issues persist, could you upload your file again with missing textures/fonts? [some are missing, you can pack them into the file...]
BellGothicStd-Bold.otf not found
Aflatoxin stick negative.png not found
full strip+texture.png not found
RevealQ+ MAX Aflatoxin HD.png not found
top.png not found
Marking as incomplete for the time being...
I downloaded build a2466049376 just now and tried it. All works fine.
Thanks.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Dec 19 2018, 2:19 PM
Glad to hear, closing then...
