crashed after change delete and choise another material
Operating system: windows 10
Graphics card: MSI GTX 950 Gaming
Broken: 2.80 BETA
OFTEN crashed after change material (select in list - in node editor or in right panel)
also in render cycles.
sory, but cant send you all scene, then you can reproduce error, model is not my own, only model, that i made.....
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Dec 18 2018, 12:49 PM
Can you reproduce the crash in a new scene or does it only happen in this file?
Which version of Blender are you using exactly (the hash on the splash screen)?
Currently I can't reproduce a crash.
hm..i cant reproduce too..
hash 4c31bed6b46
ok - include the scene-i find the way to reproduce.
open scene, open shading tab, select (if not yet) wall, in bottom node editor try to change material like in this screenshot https://yadi.sk/i/j-7WKUVIw268RQ
after that - boom! crashed! everytime.
The Blender version you are using is already more than two weeks old. Please check if the bug still happens in the newest version.
ок! Thanks! I try it later and report you.
I tried. Its the same. sorry.
i download build from December 18, 13:41:27 - hash: 8839152abf5.
you can use (for test) my scene, that i uploaded earlier.
Jacques Lucke (JacquesLucke) raised the priority of this task from 30 to 90.Dec 18 2018, 5:52 PM
Dalai Felinto (dfelinto) lowered the priority of this task from 90 to 50.
The issue seems to be with material preview "rendering" the preview_sphere object (from the preview .blend) and trying to use a material that is trying to use a UV that is not there.
That leads to the following assert:
BLI_assert failed: //source/blender/draw/intern/draw_cache_impl_mesh.c:1031, mesh_render_data_create_ex(), at 'CustomData_number_of_layers(&rdata->cd.output.ldata, CD_TANGENT) == rdata->cd.layers.tangent_len'
Full backtrace: P876
(For the records, early on I get a warning which may be related):
//blender/intern/mikktspace/mikktspace.c:1524:21: runtime error: shift exponent 32 is too large for 32-bit type 'unsigned int'
There are multiple ways of reproducing this. For example:
Just open this file and rename the UV in the mesh panel.
Thank you for interest to problem - yes...i see - i reproduce this bug - i have the same
Does it still crash for you?
Sometimes the preview is black when I try it, but it does not crash.
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.Jan 22 2019, 10:54 PM
The problem was fixed indeed. The crash no longer happens.
