version: 2.80 (sub 40), branch: master, commit date: 2019-01-06 10:51, hash: 6c7762687e57, type: Release
build date: 2019-01-06, 11:35:38
platform: Linux
Blender crashes immediately when opening file. If I save in 2.79 then open from 2.80 it will load. If I save in 2.80 it will not open again. Attached are the terminal errors, crash.txt, and file. New config file for 2.80 has no effect. Linux system is current. Does not open in the previous recent builds as well. Workaround is to append objects into new scene.
