Object Viewport Display Color Reverts To Default After Using Color Picker
Operating system: Windows 10
Graphics card: GTX 950M
Broken:
Blender 2.80
Branch: Master
Commit date: 2019-01-14
Hash: 84c06e996a7a
Object viewport display color will revert back to the default white after using the color picker, and immediately adding a second object with a non-default property. (E.g. changing the initial origin, rings/segments of a UV Sphere.)
Select the default cube.
Go to the Material tab in the Properties Editor.
Under the Viewport Display menu, use the color-picker to change the color to anything other than default.
Add any object (e.g. a Torus) to the scene.
Change any property in the New-Object pop-up menu in the lower left of the 3D View. (I'm sorry, I don't remember what this menu is called.)
The default cube will revert back to the original white color.
(This error does not occur if any other property is changed between using the color picker, and adding the second object. Nor will it occur of the color picker is not used.)
Revisions and Commits
William Reynish (billreynish) lowered the priority of this task from 90 to 50.Jan 16 2019, 9:06 AM
Good catch. Confirmed. Missing undo push when using the color picker?
Campbell Barton (campbellbarton) changed the task status from Resolved to Archived.EditedJan 18 2019, 2:16 AM
