Inset Depth behavior is incorrect
Operating system: Windows 10
Broken: 2.79b f4dc9f9d68b
When use Inset Faces Depth it stretches the selection faces to width, does not preserve the inset thickness shape
I think this behavior is incorrect
  1. Create Cylinder
  2. Select 4 faces
  3. Use Inset Faces Thickness and Depth
As far as I can tell, this is how it works in 2.79. Can you show more clearly what the problem is?
William Reynish (billreynish) changed the task status from Unknown Status to Unknown Status.Jan 21 2019, 8:46 PM
This doesn't appear to be a bug, but a suggestion for a feature inside the Inset tool.
The depth feature just offsets the result along the normals. What you are suggesting is a bit more advanced. Sounds like a nice idea.
It may be a good suggestion, but I'm almost certain it's not a bug.
How can I add a suggestion?
https://blender.community/c/rightclickselect/
This is a good place to start. Feature ideas should be as fully fleshed out as possible.
Describe the feature, why it would be useful, where it would be in the UI, Ect.
