Subdivision Surface modifier doesn't works proper in 2.80
Closed, DuplicatePublic
Operating system: Windows 10 Pro 64bit
Graphics card: AMD Radeon RX 560
Broken: 2.80 dd3f5186260e
Worked: 2.79b
When I use the Subdivision Surface modifier the object because very slow....... like a have an old PC and have frame drops. The other objects that don't have the Subdivision Surface modifier works just fine!
Just add the Subdivision Surface modifier in an object.
Console Master (ConsoleMaster) renamed this task from Subdivision Surface modifier don't works proper in 2.80 to Subdivision Surface modifier doesn't works proper in 2.80.Jan 21 2019, 9:56 PM
Without any example file or additional information, I assume this is a duplicate of T58191.
Will merge this report into T58191 then
(feel free to comment again if you think you have additional info or you think your case is different...)
