Operating system: Windows 7
Graphics card: Nvidia geforce 1050
Broken: 7f40d553f903
A keymap added from python to call a custom menu makes the menu behaves incorrectly.
The menu requires a double click in order to activate any entrie
use the default cube scene
go to edit mode
paste and run this code on text editor:
press Alt + W to activate the custom menu,
in principle, it might look ok but if you try to select an option, it requires a second click (which shouldn't).
import bpy
from bpy.types import Menu
# spawn an edit mode selection pie (run while object is in edit mode to get a valid output)
class VIEW3D_PIE_template(Menu):
# label is displayed at the center of the pie menu.
bl_label = "Select Mode"
def draw(self, context):
layout = self.layout
pie = layout.menu_pie()
# operator_enum will just spread all available options
# for the type enum of the operator on the pie
pie.operator_enum("mesh.select_mode", "type")
def register():
km = bpy.context.window_manager.keyconfigs.addon.keymaps.new(name="3D View", space_type="VIEW_3D")
kmi = km.keymap_items.new("wm.call_menu_pie", type="W", alt=True, value="PRESS")
kmi.properties.name = "VIEW3D_PIE_template"
bpy.utils.register_class(VIEW3D_PIE_template)
if __name__ == "__main__":
register()
