Operating system: Win 7 Ultimate 64 SP1
Graphics card: GTX 1060 6GB
Broken:
blender-2.80-dc3b5024be1a-win64
blender-2.80-96f762500ef9-win64
Worked: works on 2.79 (just tested it). Haven't had the need on 2.80 prior to couple of days ago ... so don't know if it ever worked.
Only 3 Vertex Color Layers can be seen in the Viewport. You can blind paint more then 3, and it does work when used in the ShaderEditor. But only 3 can be viewed in the viewport. The 4th one is displayed as all black.
So if you have 4 of them and forth one is displayed as black, if you delete one of the other 3 VertexColorLayers - then the forth one is displayed (because now you have only 3 of them again)
- Creat a Cube
- Add SubdivisionModifier with 5 levels. Apply the Modifier. (This is to create enough vertices for painting)
- Enter VertexPaint and scribble something.
- in ObjectData Tab, under VertexColors add another Layer. Scribble some more
- Repeat previous step one more time ( you will now have 3 layers and everything works fine)
- Repeat previous step one more time. Now you have 4 VertexColor Layers and this is where the bug kicks in. That fourth layer is going to be displayed in viewport as Black.
- If you delete one of the first 3 layers, that fourth one is now displayed in the viewport (because the total of VertexColorLayers is gonna be 3)
If you can not reproduce this. I can provide a startup file with the default cube and 4 VertexColorLayers
