Operating system: Kubuntu 18.04
Graphics card: NVidia GTX1060 3GB
system-info.txt generated from blender is attached.
Recreate problem:
- Fresh blend file
- Add armature (single bone)
- Add plane
- Parent plane to armature
- Select armature, go in pose mode
- Hide armature (I used the eye-icon from outliner for this)
- See mode display: it says "Object mode" now
- Try to select the plane - won't work
Solution:
- Unhide armature
- Select armature, go from pose mode back to object mode
- Hide armature again
- Now you can select the plane
Edit:
I forgot to describe the actual problem: If the user doesn't realize, that the rig got hidden while it was in pose mode, they are trapped in a state where they cant select another object.
