Box select does not select more than one object
Operating system: Windows 10
Graphics card:
Broken: 2.80 25772c9e1d2d, 2019-01-26 15:19
Try to do a box select using lmb and drag or shift+ lmb and drag or B and lmb and drag or B and shift +lmb and drag does not select any other objects than the active one.
Open new blender project with default settings. Create a duplicate of the default cube. Try to select both objects using box select.
Works fine for me. Maybe try resetting blender settings and hotkeys.
Yup. Tried that several times. Got no success with it. Will try a new download maybe? Any other tips are greatly appreciated. :)
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Jan 28 2019, 12:33 PM
@Nithin Ramesh (nithin.ramesh), please create a short .gif that shows the issue.
Other than that, just try the newest version...
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Unknown Status.Mar 7 2019, 2:30 PM
Jacques Lucke (JacquesLucke) claimed this task.
-- (zgorg) added a subscriber: -- (zgorg).EditedMar 15 2019, 1:50 AM
it doesn't work for me too. I ask for this since 4 months
-- (zgorg) added a comment.EditedMar 15 2019, 1:53 AM
I opened the bug (closed 3 times) again and I specify the HD630 graphic card. with lasso it's working^^ and when all origins is activated box select works. if not, with select box, I can only select the active object, and a lamp,but no other objects and camera. in the same collection.
and little detail the middle mouse button is no more use-able, with the new select box, to erase if we configure it
Please provide the .gif I asked for, so that I can see what you are talking about exactly.
Then reopen this report.
Hi! Ok I did a quick video
select box problem
This comment was removed by -- (zgorg).
Can´t confirm, all selection tools work as expected in Windows 10 with the latest build.
I have a Geforce GTX 1080Ti and a Geforce Titan X in my system, maybe your Intel Grafics Card is the problem?
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Unknown Status.Mar 15 2019, 12:57 PM
Jacques Lucke (JacquesLucke) raised the priority of this task from 30 to 90.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Mar 20 2019, 1:39 PM
There is already an open bug report about the box selection issue that @-- (zgorg) has: T57789: 3D viewport box select not working correct on Intel HD graphics
The bug reported by the original author may be different, but unless we can get more information from them this report can be closed.
This comment was removed by Brecht Van Lommel (brecht).
-- (zgorg) changed the task status from Unknown Status to Archived.Mar 21 2019, 9:55 PM
-- (zgorg) awarded a token.
Brecht Van Lommel (brecht) changed the task status from Archived to Unknown Status.Mar 21 2019, 10:55 PM
Brecht Van Lommel (brecht) removed a subscriber: -- (zgorg).
wow it's workinggggggggggggggggggggggggg
