Driver with input variable RNA referencing custom properties take only boolean values
Operating system: Kubuntu 18.04
Graphics card: GTX1080Ti / GTX690
Broken: 2.80, 957b4547aeeb, blender2.8, 2018-12-28, as found on the splash screen
Worked: 2.79
Drivers that reference custom properties do not update correctly.
If the custom property value is smaller than 1, it updates the driver to 0.
If the custom property value is bigger or equal to 1, it updates the driver to 1.
Problem remains with object-custom properties and armature-custom properties.
Works correctly with non-custom-property-variables.
Open a new blender file.
Create a custom property on the Default Cube Object. Increase its hard limits.
Make a driver for X location. Use single property for variable and reference the custom property by path.
Slide the custom property. X only updates to x=0 or x=1
Try in 2.79. X updates exacty to the value of the custom property.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Jan 29 2019, 12:17 PM
Can confirm. Still trying to understand what is happening..
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Unknown Status.Jan 29 2019, 12:32 PM
Jacques Lucke (JacquesLucke) claimed this task.
Ah, finally I understand why the drivers are edited in the graph editor :D
The problem in your file is that the interpolation type of the keyframes is set to "Constant". Everything works as expected when you set it back to "Linear".
https://docs.blender.org/manual/en/latest/animation/drivers/introduction.html#graph-view
