Operating system: Windows 7
Graphics card: GTX 480
Broken: 2.80 (sub 43), branch: blender2.7, commit date: 2019-02-01 01:46, hash: 552b2287db86
If a keyframe is set on a value in the mapping node in the shader editor, you can no longer change any values in this node, or any other mapping nodes. Issue persists after removing the keyframes.
- Open default file
- Open Shader Editor
- Add Mapping Node
- Set keyframe to any of the properties (e.g. Rotation)
- Try to adjust the values in the node
Edit: File with bugged mapping node, even after removing keyframe
