Blender is losing reference to collection property item when used in a recursive function?
Operating system: Ubuntu 18.04.1 LTS
Graphics card: GeForce GT 610. But I am not doing any graphics, so it's unrelated
Broken:
2.79b release
and
blender-2.80-9c68ac0448b6-linux-glibc224-x86_64 from 2019-02-07
Worked: none
I am creating a new item in collection property, and I am adding data to this item. After a recursive call of the same function, this item is not accessible. Details of errors are in the python code comments.
Base on the default startup blend file, load my python script to a text editor and run a script. No errors yet. Find the button "Load tree from json" (properties in 3d viewport) and press it.
An error does not appear when pressed again. You will have to restart blender to repeat the error.
Script
Crash report from blender 2.8
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Feb 8 2019, 11:34 AM
RNA_def_property: runtime property identifier "TreeItems.items" - this keyword is reserved by python
Since this is a reserved keyword, try renaming your property to something else:
class TreeItems(bpy.types.PropertyGroup):
    if bpy.app.version >= (2,80,0):
        str_id: bpy.props.StringProperty()
        _items: bpy.props.StringProperty(default='')
and change that elsewhere in the code as well, should be good to go then, see
Will close this as resolved, but feel free to comment again if issues persist...
I regret to write: it is not it :(.
I changed init to sub_init and I steel get TypeError: unsubscriptable object.
Regards
Philipp Oeser (lichtwerk) changed the task status from Resolved to Unknown Status.Feb 8 2019, 9:01 PM
That was probably a bit too quick on my side, need to look at that again (on Monday)...
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.Feb 12 2019, 1:11 PM
Can confirm the crash (when accessing/printing the current_item after the recursive call)
1   BPy_IDGroup_WrapData             idprop_py_api.c      143  0x23aac17
2   BPy_Wrap_GetValues               idprop_py_api.c      963  0x23acb99
3   pyrna_struct_values              bpy_rna.c            3394 0x2378203
4   _PyMethodDef_RawFastCallKeywords                           0x7ffff79c4561
5   _PyCFunction_FastCallKeywords                              0x7ffff79c4700
6   _PyEval_EvalFrameDefault                                   0x7ffff7a33bd3
7   _PyEval_EvalCodeWithName                                   0x7ffff797df28
8   _PyFunction_FastCallKeywords                               0x7ffff79c3e81
9   _PyEval_EvalFrameDefault                                   0x7ffff7a2ea9c
10  _PyEval_EvalCodeWithName                                   0x7ffff797df28
11  _PyFunction_FastCallKeywords                               0x7ffff79c3e81
12  _PyEval_EvalFrameDefault                                   0x7ffff7a2ea9c
13  _PyFunction_FastCallDict                                   0x7ffff797ef2a
14  bpy_class_call                   bpy_rna.c            7919 0x237fda0
15  rna_operator_execute_cb          rna_wm.c             1228 0x2ea0ad9
16  wm_operator_invoke               wm_event_system.c    1347 0x1ca859a
17  wm_operator_call_internal        wm_event_system.c    1544 0x1ca8c20
18  WM_operator_name_call_ptr        wm_event_system.c    1592 0x1ca8e43
19  ui_apply_but_funcs_after         interface_handlers.c 769  0x1fc0cf7
20  ui_handler_region_menu           interface_handlers.c 9855 0x1fd8ca2
... <More>
However, this might be expected [to get into trouble after a recursive call], since the local variable is just a reference to the same object?
https://stackoverflow.com/questions/24572089/trouble-with-variable-scope-in-recursive-function-python
You are also using enumerate here [which is different from just looping over a list, but I am uncertain about the python internals...]
I made a 2nd try here:
  • replace the enumerate with just plain loop over list
  • made a deepcopy of the sub_branch prior to passing it to the recursive call
  • not sure if everything is behaving as expected, but could you check on this?
Since I am really on shaky ground here, I would like to ask:
@Bastien Montagne (mont29), @Campbell Barton (campbellbarton) : is this expected? [to get into trouble when using enumerate + recursive function calls?] Is dropping enumerate (in favor of in list) plus making a deepcopy the desired/correct solution here?
Will mark this as Normal priority for now...
This .blend file You attached is (as far as I know) default init blend file, so I can't check what You have changed. Please attach the changed .py file.
I followed Your directions:
  • I removed enumerate (It was there for testing purposes anyway), but this did not solve the problem.
  • I assume that Your step 2 was passing 'deepcopy(branch['sub_items'])' instead of ''branch['sub_items'] into the recursive function. It did not solve the problem for me (did it for You?). Please remember that (like I wrote in the comments of my py file) calling operator again does not replicate the error: "I have to restart blender to repeat the error". And after that changes error is still there. Also, the problem from Your link is little different from mine, because my problem is with 'current_item' variable (not with ''branch['sub_items']"). I am not passing 'current_item' to the recursive call, and as far as I know my current_tems variables from every scope point to a different object, coz I create it in the scope, not passing it as a parameter.
Regards.
Sorry, Your blend file was not empty, my mistake. But the error still occurs.
@Piotr Kowalczyk (dopiotrko) : changed py is in that file (just didnt rename it -- e.g. look for _sub_branch = deepcopy(sub_branch))
and yes, that solved the error on my side...
  • I can open my file, run the script, run the operator without errors
  • I can restart blender, do the above, without errors
I can only repeat myself: I am on shaky ground here, if the above file doesnt work for you, I am probably out of ideas...
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Feb 12 2019, 2:43 PM
First of all, this is not a bug report at all, and should not be handled here. We have a site for that kind of question: https://devtalk.blender.org/
Would be a bug report if you had done investigation, and generated from it a very simple demo script of the issue, instead of giving us your full project one:
import bpy
def recursive_idprop_user(context, counter=10):
    counter -= 1
    if counter == 0:
        return
    curr_item = context.scene.tree_items.add()
    recursive_idprop_user(context, counter)
    curr_item.name = str(counter)
    print(curr_item.values())
class FooBar_OT_test(bpy.types.Operator):
    bl_idname = "foobar.test"
    bl_label = "Test recursive IDProp handling"
    def execute(self, context):
        recursive_idprop_user(context, 10)
        return {"FINISHED"}
def register():
    bpy.utils.register_class(TreeItems)
    bpy.utils.register_class(FooBar_OT_test)
    bpy.types.Scene.tree_items = bpy.props.CollectionProperty(type=TreeItems)
if __name__ == "__main__":
    register()
That should also have made it obvious that there is no bug at all here, you are just keeping reference of some Blender data while modifying container of that data, which is always dangerous. That simple modification is enough to make example work:
import bpy
    counter -= 1
    if counter == 0:
        return
    curr_item_idx = len(context.scene.tree_items) - 1
    curr_item = context.scene.tree_items[curr_item_idx]
        return {"FINISHED"}
def register():
    register()
Did not check your actual code, but pretty sure this will fix it. Also, will update the doc the make this point more obvious, we describe several common case of that issue but it's not enough standing out that this can happen with pretty much *any* data owned by Blender…
thanx @Bastien Montagne (mont29) for clearing that up! (sorry for my uneducated fiddeling here...)
Ok. Thanks for Your help, and sorry for posting it here.
