Cycles render Crashes when I was testing some assets in render preview in this file but in other files I was testing too.
Thanks!
Model: iMac17,1, BootROM 161.0.0.0.0, 4 processors, Intel Core i5, 3,3 GHz, 32 GB, SMC 2.34f2
Graphics: AMD Radeon R9 M395, AMD Radeon R9 M395, PCIe
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x802C, 0x31364B544631473634485A2D314739503120
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1867 MHz, 0x802C, 0x31364B544631473634485A2D314739503120
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1867 MHz, 0x802C, 0x31364B544631473634485A2D314739503120
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1867 MHz, 0x802C, 0x31364B544631473634485A2D314739503120
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.77.61.1 AirPortDriverBrcmNIC-1305.2)
Bluetooth: Version 6.0.10f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: APPLE HDD ST2000DM001, 2 TB
Serial ATA Device: APPLE SSD SM0128G, 121,33 GB
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: BUP RD
USB Device: USB2.0 Hub
USB Device: USB Optical Mouse
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: TABLET MONITOR
USB Device: Magic Keyboard
Thunderbolt Bus: iMac, Apple Inc., 28.1
Broken:
(example: 2.79b release)
Process: blender [1393]
Path: /Applications/blender-2.80/blender_beta.app/Contents/MacOS/blender
Identifier: org.blenderfoundation.blender
Version: 2.80 (2.80 2019-02-07, Blender Foundation)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: blender [1393]
User ID: 501
Date/Time: 2019-02-09 14:12:19.084 +0100
OS Version: Mac OS X 10.14.3 (18D109)
Report Version: 12
Anonymous UUID: EEB68886-7E19-C360-684B-AD77F44821B7
Sleep/Wake UUID: 51D94F97-5B08-47C4-902A-75F079F115B5
Time Awake Since Boot: 58000 seconds
Time Since Wake: 11000 seconds
System Integrity Protection: disabled
Crashed Thread: 20
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000117cce650
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Bus error: 10
Termination Reason: Namespace SIGNAL, Code 0xa
Terminating Process: exc handler [1393]
VM Regions Near 0x117cce650:
VM_ALLOCATE 0000000117ccd000-0000000117cce000 [ 4K] rw-/rwx SM=ZER
--> VM_ALLOCATE 0000000117cce000-0000000117ccf000 [ 4K] r-x/rwx SM=ZER
VM_ALLOCATE 0000000117ccf000-0000000117cd0000 [ 4K] rw-/rwx SM=ZER
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff69b76eae __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff69b01830 nanosleep + 199
2 libsystem_c.dylib 0x00007fff69b01724 usleep + 53
3 org.blenderfoundation.blender 0x00000001089b6348 WM_main + 24
4 org.blenderfoundation.blender 0x00000001089b21d9 main + 969
5 libdyld.dylib 0x00007fff69a39ed9 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff69b767de psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff69c30593 _pthread_cond_wait + 724
2 libc++.1.dylib 0x00007fff6710ebda std::1::condition_variable::wait(std::1::unique_lock<std::1::mutex>&) + 18
3 org.blenderfoundation.blender 0x000000010b9a0e63 IlmThread_2_3::Semaphore::wait() + 147
4 org.blenderfoundation.blender 0x000000010b99e3c2 IlmThread_2_3::(anonymous namespace)::DefaultWorkerThread::run() + 66
5 org.blenderfoundation.blender 0x000000010b9a08b7 void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (IlmThread_2_3::Thread::*)(), IlmThread_2_3::Thread*> >(void*) + 663
6 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
7 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
8 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 2:
Thread 3:
Thread 4:
Thread 5:
0 libsystem_kernel.dylib 0x00007fff69b767de __psynch_cvwait + 10
2 org.blenderfoundation.blender 0x000000010953a51c task_scheduler_thread_run + 124
3 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
4 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
5 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 6:
Thread 7:
Thread 8:
0 libsystem_kernel.dylib 0x00007fff69b79716 kevent + 10
1 select.cpython-37m-darwin.so 0x000000011d10533e kqueue_queue_control + 974
2 org.blenderfoundation.blender 0x000000010ac54b9b _PyMethodDef_RawFastCallKeywords + 251
3 org.blenderfoundation.blender 0x000000010ac5a9a2 _PyMethodDescr_FastCallKeywords + 82
4 org.blenderfoundation.blender 0x000000010ad26393 call_function + 659
5 org.blenderfoundation.blender 0x000000010ad1e408 _PyEval_EvalFrameDefault + 4088
6 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
7 org.blenderfoundation.blender 0x000000010ad26378 call_function + 632
8 org.blenderfoundation.blender 0x000000010ad1e408 _PyEval_EvalFrameDefault + 4088
9 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
10 org.blenderfoundation.blender 0x000000010ad26378 call_function + 632
11 org.blenderfoundation.blender 0x000000010ad1e408 _PyEval_EvalFrameDefault + 4088
12 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
13 org.blenderfoundation.blender 0x000000010ad26378 call_function + 632
14 org.blenderfoundation.blender 0x000000010ad1e408 _PyEval_EvalFrameDefault + 4088
15 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
16 org.blenderfoundation.blender 0x000000010ac55076 _PyObject_Call_Prepend + 150
17 org.blenderfoundation.blender 0x000000010ac54208 PyObject_Call + 136
18 org.blenderfoundation.blender 0x000000010ad1e7c1 _PyEval_EvalFrameDefault + 5041
19 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
20 org.blenderfoundation.blender 0x000000010ad26378 call_function + 632
21 org.blenderfoundation.blender 0x000000010ad1e408 _PyEval_EvalFrameDefault + 4088
22 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
23 org.blenderfoundation.blender 0x000000010ad26378 call_function + 632
24 org.blenderfoundation.blender 0x000000010ad1e408 _PyEval_EvalFrameDefault + 4088
25 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
26 org.blenderfoundation.blender 0x000000010ac55076 _PyObject_Call_Prepend + 150
27 org.blenderfoundation.blender 0x000000010ac54208 PyObject_Call + 136
28 org.blenderfoundation.blender 0x000000010adb2997 t_bootstrap + 71
29 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
30 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
31 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 9:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff69b7317a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff69b736d0 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff3c7e8fde CFRunLoopServiceMachPort + 337
3 com.apple.CoreFoundation 0x00007fff3c7e852d CFRunLoopRun + 1654
4 com.apple.CoreFoundation 0x00007fff3c7e7c64 CFRunLoopRunSpecific + 463
5 com.apple.AppKit 0x00007fff39d41f89 _NSEventThread + 160
Thread 10:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fff3c23889a HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 124
3 com.apple.audio.CoreAudio 0x00007fff3c23880d HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4 com.apple.audio.CoreAudio 0x00007fff3c234b84 HALC_ProxyIOContext::IOWorkLoop() + 988
5 com.apple.audio.CoreAudio 0x00007fff3c2345ee HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6 com.apple.audio.CoreAudio 0x00007fff3c2340d6 HALB_IOThread::Entry(void*) + 72
7 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
8 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
9 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 11:
3 org.blenderfoundation.blender 0x000000010b7474af OpenImageIO_v1_8::thread_pool::Impl::set_thread(int)::'lambda'()::operator()() const + 303
4 org.blenderfoundation.blender 0x000000010b7472ad void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, OpenImageIO_v1_8::thread_pool::Impl::set_thread(int)::'lambda'()> >(void*) + 45
5 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
6 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
7 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 12:
Thread 13:
Thread 14:
0 libsystem_pthread.dylib 0x00007fff69c2c3f8 start_wqthread + 0
1 ??? 0x0000000054485244 0 + 1414025796
Thread 15:
Thread 16:
3 org.blenderfoundation.blender 0x000000010a7d1a4b ccl::TaskScheduler::thread_wait_pop(ccl::TaskScheduler::Entry&) + 91
4 org.blenderfoundation.blender 0x000000010a7d1812 ccl::TaskScheduler::thread_run(int) + 130
5 org.blenderfoundation.blender 0x000000010a7d3095 ccl::thread::run(void*) + 37
6 org.blenderfoundation.blender 0x000000010a7d32bc void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void* (*)(void*), ccl::thread*> >(void*) + 44
Thread 17:
Thread 18:
Thread 19:
Thread 20 Crashed:
0 ??? 0x0000000117cce650 0 + 4694271568
1 org.blenderfoundation.blender 0x00000001088b3bc9 OSL_v1_9::ShadingContext::execute(OSL_v1_9::ShaderGroup&, OSL_v1_9::ShaderGlobals&, bool) + 185
2 org.blenderfoundation.blender 0x000000010a7c34ee ccl::OSLShader::eval_background(ccl::KernelGlobals*, ccl::ShaderData*, ccl::PathState*, int) + 78
3 org.blenderfoundation.blender 0x0000000109f5c247 ccl::kernel_cpu_avx2_shader(ccl::KernelGlobals*, ccl::uint4*, ccl::float4*, int, int, int, int, int) + 583
4 org.blenderfoundation.blender 0x000000010981b937 ccl::CPUDevice::thread_shader(ccl::DeviceTask&) + 263
5 org.blenderfoundation.blender 0x000000010a7d086b ccl::TaskPool::wait_work(ccl::TaskPool::Summary*) + 219
6 org.blenderfoundation.blender 0x000000010989d419 ccl::LightManager::device_update_background(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&) + 1833
7 org.blenderfoundation.blender 0x000000010989ef61 ccl::LightManager::device_update(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&) + 385
8 org.blenderfoundation.blender 0x00000001098ff59d ccl::Scene::device_update(ccl::Device*, ccl::Progress&) + 2941
9 org.blenderfoundation.blender 0x0000000109903999 ccl::Session::update_scene() + 361
10 org.blenderfoundation.blender 0x0000000109904bfb ccl::Session::run_cpu() + 379
11 org.blenderfoundation.blender 0x00000001099028d0 ccl::Session::run() + 320
12 org.blenderfoundation.blender 0x000000010a7d3095 ccl::thread::run(void*) + 37
13 org.blenderfoundation.blender 0x000000010a7d32bc void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void* (*)(void*), ccl::thread*> >(void*) + 44
14 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
15 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
16 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 21:
0 libsystem_kernel.dylib 0x00007fff69b7594e ulock_wait + 10
1 libsystem_pthread.dylib 0x00007fff69c3170a _pthread_join + 356
2 libc++.1.dylib 0x00007fff6714f978 std::1::thread::join() + 24
3 org.blenderfoundation.blender 0x000000010a7d3195 ccl::thread::join() + 21
4 org.blenderfoundation.blender 0x000000010990250b ccl::Session::wait() + 27
5 org.blenderfoundation.blender 0x00000001097f8676 ccl::BlenderSession::render(BL::Depsgraph&) + 3718
6 org.blenderfoundation.blender 0x00000001097effce ccl::render_func(_object*, _object*) + 206
7 org.blenderfoundation.blender 0x000000010ac54b9b _PyMethodDef_RawFastCallKeywords + 251
8 org.blenderfoundation.blender 0x000000010ac540ec _PyCFunction_FastCallKeywords + 44
9 org.blenderfoundation.blender 0x000000010ad262e8 call_function + 488
10 org.blenderfoundation.blender 0x000000010ad1e422 _PyEval_EvalFrameDefault + 4114
11 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
12 org.blenderfoundation.blender 0x000000010ad26378 call_function + 632
13 org.blenderfoundation.blender 0x000000010ad1e422 _PyEval_EvalFrameDefault + 4114
14 org.blenderfoundation.blender 0x000000010ac545e0 function_code_fastcall + 256
15 org.blenderfoundation.blender 0x0000000108da7871 bpy_class_call + 961
16 org.blenderfoundation.blender 0x000000010942fba1 engine_render + 113
17 org.blenderfoundation.blender 0x0000000108d765b5 RE_engine_render + 965
18 org.blenderfoundation.blender 0x0000000108cd8181 shader_preview_render + 1105
19 org.blenderfoundation.blender 0x0000000108cd7a36 common_preview_startjob + 566
20 org.blenderfoundation.blender 0x0000000108cd7307 icon_preview_startjob_all_sizes + 311
21 org.blenderfoundation.blender 0x00000001089cb374 do_job_thread + 36
22 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
23 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
24 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 22:
3 org.blenderfoundation.blender 0x000000010887c23e OSL_v1_9::pvt::ShadingSystemImpl::optimize_all_groups(int, int, int) + 974
4 org.blenderfoundation.blender 0x00000001098f5605 ccl::OSLShaderManager::device_update(ccl::Device*, ccl::DeviceScene*, ccl::Scene*, ccl::Progress&) + 853
5 org.blenderfoundation.blender 0x00000001098feb73 ccl::Scene::device_update(ccl::Device*, ccl::Progress&) + 339
6 org.blenderfoundation.blender 0x0000000109903999 ccl::Session::update_scene() + 361
7 org.blenderfoundation.blender 0x0000000109904bfb ccl::Session::run_cpu() + 379
8 org.blenderfoundation.blender 0x00000001099028d0 ccl::Session::run() + 320
9 org.blenderfoundation.blender 0x000000010a7d3095 ccl::thread::run(void*) + 37
10 org.blenderfoundation.blender 0x000000010a7d32bc void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void* (*)(void*), ccl::thread*> >(void*) + 44
11 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
12 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
13 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 23:
0 org.blenderfoundation.blender 0x000000010d96d67f llvm::ScheduleDAGSDNodes::newSUnit(llvm::SDNode*) + 191
1 org.blenderfoundation.blender 0x000000010d96e58f llvm::ScheduleDAGSDNodes::BuildSchedUnits() + 383
2 org.blenderfoundation.blender 0x000000010d96fa36 llvm::ScheduleDAGSDNodes::BuildSchedGraph(llvm::AAResults*) + 118
3 org.blenderfoundation.blender 0x000000010d964a3d (anonymous namespace)::ScheduleDAGRRList::Schedule() + 461
4 org.blenderfoundation.blender 0x000000010d9fed76 llvm::SelectionDAGISel::CodeGenAndEmitDAG() + 1702
5 org.blenderfoundation.blender 0x000000010d9fda80 llvm::SelectionDAGISel::SelectAllBasicBlocks(llvm::Function const&) + 9104
6 org.blenderfoundation.blender 0x000000010d9fac7d llvm::SelectionDAGISel::runOnMachineFunction(llvm::MachineFunction&) + 1709
7 org.blenderfoundation.blender 0x000000010d6fd8a4 (anonymous namespace)::X86DAGToDAGISel::runOnMachineFunction(llvm::MachineFunction&) + 20
8 org.blenderfoundation.blender 0x000000010dc0e5b6 llvm::MachineFunctionPass::runOnFunction(llvm::Function&) + 134
9 org.blenderfoundation.blender 0x000000010e47cf72 llvm::FPPassManager::runOnFunction(llvm::Function&) + 546
10 org.blenderfoundation.blender 0x000000010e47d183 llvm::FPPassManager::runOnModule(llvm::Module&) + 67
11 org.blenderfoundation.blender 0x000000010e47d5f8 llvm::legacy::PassManagerImpl::run(llvm::Module&) + 888
12 org.blenderfoundation.blender 0x000000010dae87e9 llvm::MCJIT::emitObject(llvm::Module*) + 233
13 org.blenderfoundation.blender 0x000000010dae8a5b llvm::MCJIT::generateCodeForModule(llvm::Module*) + 139
14 org.blenderfoundation.blender 0x000000010dae9501 llvm::MCJIT::finalizeObject() + 385
15 org.blenderfoundation.blender 0x000000010898b650 OSL_v1_9::pvt::LLVM_Util::getPointerToFunction(llvm::Function*) + 48
16 org.blenderfoundation.blender 0x0000000108988439 OSL_v1_9::pvt::BackendLLVM::run() + 2777
17 org.blenderfoundation.blender 0x000000010887e715 OSL_v1_9::pvt::ShadingSystemImpl::optimize_group(OSL_v1_9::ShaderGroup&) + 2229
18 org.blenderfoundation.blender 0x000000010887c1a4 OSL_v1_9::pvt::ShadingSystemImpl::optimize_all_groups(int, int, int) + 820
19 org.blenderfoundation.blender 0x00000001088966b1 void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (*)(OSL_v1_9::pvt::ShadingSystemImpl*, int, int), OSL_v1_9::pvt::ShadingSystemImpl*, int, int> >(void*) + 49
20 libsystem_pthread.dylib 0x00007fff69c2d305 _pthread_body + 126
21 libsystem_pthread.dylib 0x00007fff69c3026f _pthread_start + 70
22 libsystem_pthread.dylib 0x00007fff69c2c415 thread_start + 13
Thread 20 crashed with X86 Thread State (64-bit):
rax: 0x0000000117cce650 rbx: 0x0000000000000003 rcx: 0x0000000000000003 rdx: 0x0000000000000003 rdi: 0x00007fd9fba49600 rsi: 0x0000600003eaa480 rbp: 0x00007000020fd0f0 rsp: 0x00007000020fd0a8 r8: 0x0000600003eaa4f8 r9: 0x0000000000000078 r10: 0x0000000000000000 r11: 0x0000000000000000 r12: 0x0000000000000000 r13: 0x0000000000000001 r14: 0x00007fd9fba49600 r15: 0x00007fd9f5862400 rip: 0x0000000117cce650 rfl: 0x0000000000010206 cr2: 0x0000000117cce650
Logical CPU: 1
Error Code: 0x00000007
Trap Number: 14
Binary Images:
0x108868000 - 0x10fa62f3f +org.blenderfoundation.blender (2.80 - 2.80 2019-02-07, Blender Foundation) <5785D6CC-FE6C-3A8F-A361-6E2608E98D84> /Applications/blender-2.80/blender_beta.app/Contents/MacOS/blender 0x113026000 - 0x113087ff7 +libomp.dylib (0) <C32CE1B6-6F34-34E2-B9A3-7B8AD010CE68> /Applications/blender-2.80/blender_beta.app/Contents/Resources/lib/libomp.dylib 0x113ddf000 - 0x113f84ff7 com.apple.audio.units.Components (1.14 - 1.14) <A7E7DE74-B219-308E-8177-7F1AC561DB93> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio 0x115a06000 - 0x115a0afff com.apple.audio.AppleHDAHALPlugIn (282.10 - 282.10) <8C1742CF-F0B3-3321-9918-F5237B84CF5A> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn 0x1188ff000 - 0x118902047 libobjc-trampolines.dylib (750.1) <0D004834-E2EB-3066-8598-6F413521157F> /usr/lib/libobjc-trampolines.dylib 0x11890b000 - 0x1189d4ff7 com.apple.AMDRadeonX4000GLDriver (2.4.10 - 2.0.4) <BD5AEDB7-59B1-3D64-916A-3A8948AF2BA7> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver 0x118b4b000 - 0x118b4bfff +libcuda.dylib (0) <0094DEFF-0569-3F0E-BFBD-91FC4FE32673> /usr/local/cuda/lib/libcuda.dylib 0x11a5e4000 - 0x11a5e9ff7 +math.cpython-37m-darwin.so (0) <8E3040CF-1D6C-31F6-877B-1A1834678F7E> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/math.cpython-37m-darwin.so 0x11a8b0000 - 0x11a8b1ff7 +_heapq.cpython-37m-darwin.so (0) <4E38D5FE-D41E-3D73-A691-D8EB68705BA1> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_heapq.cpython-37m-darwin.so 0x11a986000 - 0x11a986ff3 +_uuid.cpython-37m-darwin.so (0) <45E1A652-BAB3-3344-869B-1D017F555BE2> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_uuid.cpython-37m-darwin.so 0x11a989000 - 0x11a989ff7 +grp.cpython-37m-darwin.so (0) <AA247678-891C-37A1-A366-A0BE90EF1D3E> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/grp.cpython-37m-darwin.so 0x11a98c000 - 0x11a98dfff +_posixsubprocess.cpython-37m-darwin.so (0) <B2A0F21A-FA24-3367-8DA7-955EC01F9F20> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_posixsubprocess.cpython-37m-darwin.so 0x11a991000 - 0x11a991fff +_bisect.cpython-37m-darwin.so (0) <C909A01A-F1E7-3D1D-A5AB-98732EBF216C> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_bisect.cpython-37m-darwin.so 0x11d103000 - 0x11d105fff +select.cpython-37m-darwin.so (0) <26D5EDA8-B65D-3FA8-BC0C-067B0832CB76> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/select.cpython-37m-darwin.so 0x11d12b000 - 0x11d13efff +zlib.cpython-37m-darwin.so (0) <CFDBAC71-3FD7-375A-9BB3-7B5CC9FF0109> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/zlib.cpython-37m-darwin.so 0x11d145000 - 0x11d146ff7 +_random.cpython-37m-darwin.so (0) <AD8E66EB-9B24-3069-9F19-CAD4D3082EA5> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_random.cpython-37m-darwin.so 0x11d1eb000 - 0x11d201ffb +_bz2.cpython-37m-darwin.so (0) <FC38E3EA-D478-3802-AF69-2211D2EDC00E> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_bz2.cpython-37m-darwin.so 0x11d207000 - 0x11d235ff3 +_lzma.cpython-37m-darwin.so (0) <0198C72D-AF2B-318E-B289-BFF182223049> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_lzma.cpython-37m-darwin.so 0x11d27f000 - 0x11d285fff +_json.cpython-37m-darwin.so (0) <8DF6F5D7-0EB1-3392-842C-43CDAA937716> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_json.cpython-37m-darwin.so 0x11d28a000 - 0x11d413f1b +_hashlib.cpython-37m-darwin.so (0) <38CFAA99-1DA3-3B68-B839-6448E965E591> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_hashlib.cpython-37m-darwin.so 0x11d486000 - 0x11d48cff3 +_blake2.cpython-37m-darwin.so (0) <CD71A5DC-5265-3F3A-AB67-4C57E26DCF3E> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_blake2.cpython-37m-darwin.so 0x11d491000 - 0x11d4a1fff +_sha3.cpython-37m-darwin.so (0) <CDF4870A-0030-3AFD-89A4-9456044C5447> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_sha3.cpython-37m-darwin.so 0x11d6a7000 - 0x11d822ffb +multiarray.cpython-37m-darwin.so (0) <B7E77095-9302-3E2F-B96C-888FBEAA37A4> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/core/multiarray.cpython-37m-darwin.so 0x11d93b000 - 0x11d949ff3 +_datetime.cpython-37m-darwin.so (0) <2EFD843A-A680-3502-9AF8-CAC13392DBAF> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_datetime.cpython-37m-darwin.so 0x11d955000 - 0x11dad9fef +umath.cpython-37m-darwin.so (0) <3A6ADA7B-AFCE-3D5D-9D13-C0FBC17FA2D7> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/core/umath.cpython-37m-darwin.so 0x11db60000 - 0x11db71ff7 +_ctypes.cpython-37m-darwin.so (0) <F2700E51-D61D-389E-98FB-6DDCA054A5C0> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_ctypes.cpython-37m-darwin.so 0x11db82000 - 0x11db86ff7 +_struct.cpython-37m-darwin.so (0) <7274B4CF-30C4-359F-A572-311BBB3AF07E> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_struct.cpython-37m-darwin.so 0x11dbcf000 - 0x11dbe1ff7 +_pickle.cpython-37m-darwin.so (0) <09C49DA7-8D62-3DEC-B09C-C5CC68513E38> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_pickle.cpython-37m-darwin.so 0x11dced000 - 0x11dceefff +lapack_lite.cpython-37m-darwin.so (0) <7CAE77EA-F8F5-3733-9DF0-CE5C59A05FBE> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/linalg/lapack_lite.cpython-37m-darwin.so 0x11dcf2000 - 0x11dd0aff7 +_umath_linalg.cpython-37m-darwin.so (0) <F57E021A-00A8-318A-A848-F3C08DE6225A> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/linalg/_umath_linalg.cpython-37m-darwin.so 0x11dd58000 - 0x11dd95fff +_decimal.cpython-37m-darwin.so (0) <EF01B745-510C-3153-AEEA-62CB80C28F8D> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_decimal.cpython-37m-darwin.so 0x11ddf4000 - 0x11de00ff3 +_multiarray_tests.cpython-37m-darwin.so (0) <6030FF7C-8D5D-3B9C-B5A9-ABDFDECB0BB0> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/core/_multiarray_tests.cpython-37m-darwin.so 0x11de0f000 - 0x11de17ffb +fftpack_lite.cpython-37m-darwin.so (0) <B8FB732C-EBD4-3C62-93E0-8F87085ABF77> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/fft/fftpack_lite.cpython-37m-darwin.so 0x11de5b000 - 0x11defbffb +mtrand.cpython-37m-darwin.so (0) <EC9D9550-40F2-3E55-A7F7-7900749C9C3E> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/site-packages/numpy/random/mtrand.cpython-37m-darwin.so 0x11e101000 - 0x11e10afff +_socket.cpython-37m-darwin.so (0) <90B3F9AD-F64E-3299-8F12-A73E2FA6858F> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_socket.cpython-37m-darwin.so 0x11e157000 - 0x11e335e77 +_ssl.cpython-37m-darwin.so (0) <98B09902-6EC2-3ED4-9DB9-544C83FFED4C> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_ssl.cpython-37m-darwin.so 0x11e40b000 - 0x11e411fff +binascii.cpython-37m-darwin.so (0) <B615E34C-19F5-3D36-9CAD-1ED22A28B567> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/binascii.cpython-37m-darwin.so 0x11e496000 - 0x11e496fff +_queue.cpython-37m-darwin.so (0) <6CFDFB1E-6E36-3682-851F-958D105DE3F1> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_queue.cpython-37m-darwin.so 0x11e65a000 - 0x11e65aff3 +_scproxy.cpython-37m-darwin.so (0) <39F4D34A-DAAC-3770-B88C-7E04BFB4C3CC> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_scproxy.cpython-37m-darwin.so 0x11e69d000 - 0x11e79bffb +unicodedata.cpython-37m-darwin.so (0) <611AE8CC-993D-3D1E-B999-E49DDECB7C08> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/unicodedata.cpython-37m-darwin.so 0x11e9a1000 - 0x11e9a1ffb +_opcode.cpython-37m-darwin.so (0) <42391283-A009-3020-AB22-C8CE490627E8> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_opcode.cpython-37m-darwin.so 0x11ea24000 - 0x11ea51ff3 +pyexpat.cpython-37m-darwin.so (0) <459F6A95-CB68-32A0-BF7C-D727EB0C3D21> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/pyexpat.cpython-37m-darwin.so 0x11ec64000 - 0x11ec6afff +array.cpython-37m-darwin.so (0) <EF417ADC-162F-3E81-AAA6-F0B422A8AE5E> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/array.cpython-37m-darwin.so 0x11f416000 - 0x11f421ff7 +_curses.cpython-37m-darwin.so (0) <C4D2015D-C03F-3ACA-8705-DF3C8C950D9C> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_curses.cpython-37m-darwin.so 0x11f52d000 - 0x11f52eff3 +fcntl.cpython-37m-darwin.so (0) <85C205BA-1327-3A7B-84A5-B0F98FFD76CA> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/fcntl.cpython-37m-darwin.so 0x11f6b2000 - 0x11f6b2fff +_contextvars.cpython-37m-darwin.so (0) <A277E347-503E-353C-A188-25C949CD72BF> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_contextvars.cpython-37m-darwin.so 0x11f6b5000 - 0x11f6baff3 +_asyncio.cpython-37m-darwin.so (0) <34954FE2-7884-3E3C-AEFB-9273B51A5160> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_asyncio.cpython-37m-darwin.so 0x11f7c6000 - 0x11f7c9ff3 +_csv.cpython-37m-darwin.so (0) <D7BCCA2E-FCD2-336B-A30C-268274DADE2F> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_csv.cpython-37m-darwin.so 0x11fbfb000 - 0x11fc03ff3 +_elementtree.cpython-37m-darwin.so (0) <25494C81-F5D5-3E04-9FFA-F341741AD941> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/_elementtree.cpython-37m-darwin.so 0x11fc0d000 - 0x11fc0effb +termios.cpython-37m-darwin.so (0) <0083173C-F962-3526-B926-3B3BDA00525F> /Applications/blender-2.80/blender_beta.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload/termios.cpython-37m-darwin.so 0x120c60000 - 0x120cdea87 dyld (655.1) <3EBA447F-A546-366B-B302-8DC3B21A3E30> /usr/lib/dyld 0x124a21000 - 0x124a2cfff +CUDA (0) <B1271103-48EA-3E7D-92B7-8DD3398E4AC6> /Library/Frameworks/CUDA.framework/Versions/A/CUDA 0x7fff32642000 - 0x7fff329bbfff com.apple.RawCamera.bundle (8.13.0 - 1031.3.2) <C1DB8AE5-1683-3AE8-ACDD-C5EBB3682EE8> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x7fff329be000 - 0x7fff32b09fff com.apple.AMDMTLBronzeDriver (2.4.10 - 2.0.4) <D06807E4-FC1B-3AE6-AA16-428CE745F924> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver 0x7fff32b0a000 - 0x7fff33283fff ATIRadeonX4000SCLib.dylib (2.4.10) <EF35E927-BE8C-3567-8934-153CA3328250> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib 0x7fff38ad9000 - 0x7fff38ad9fff com.apple.Accelerate (1.11 - Accelerate 1.11) <A09CB6D5-3F8A-3E05-B0EB-63878296A059> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff38ada000 - 0x7fff38af0fef libCGInterfaces.dylib (506.19.1) <55B9EFFF-6719-381E-B7F3-C3AA07F5D78F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib 0x7fff38af1000 - 0x7fff39191fe3 com.apple.vImage (8.1 - ???) <BDA40EB0-9B20-3ACF-BE37-199578FA84F4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff39192000 - 0x7fff39409fd7 libBLAS.dylib (1243.200.4) <0ADBEAE3-6636-33E5-AC9F-11C2249E19D3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff3940a000 - 0x7fff3947cfe7 libBNNS.dylib (38.200.5) <CC93B9B5-2A8C-3D42-9234-75DD41EC8C0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib 0x7fff3947d000 - 0x7fff39823fff libLAPACK.dylib (1243.200.4) <45722A8A-5788-3C4C-ADD9-1812763FA635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff39824000 - 0x7fff39839ffb libLinearAlgebra.dylib (1243.200.4) <3923AB79-213E-32FD-AC87-8B1A1A832336> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff3983a000 - 0x7fff3983fff3 libQuadrature.dylib (3.200.2) <4FBCAC0A-81A4-3C53-8458-27F3569C809D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib 0x7fff39840000 - 0x7fff398bdffb libSparse.dylib (79.200.5) <2D650C50-E87E-3F24-9BFA-C8EB6DE1A6E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib 0x7fff398be000 - 0x7fff398d1ffb libSparseBLAS.dylib (1243.200.4) <6F8C78BE-A0FD-3507-8A95-541AFC57F1EE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fff398d2000 - 0x7fff39ab6ff3 libvDSP.dylib (671.220.1) <2F576522-08B1-3C65-8F00-3427E938ADDA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff39ab7000 - 0x7fff39b6cff3 libvMisc.dylib (671.220.1) <D7B5F89D-3310-31F4-B8BF-42DA300ABE64> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff39b6d000 - 0x7fff39b6dfff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <221E4FEF-0431-3316-8281-22B6F8315A09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff39d1e000 - 0x7fff3ab3fffb com.apple.AppKit (6.9 - 1671.20.108) <D460682F-1B60-372E-A8E5-58D7F3A1CB3A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff3ab91000 - 0x7fff3ab91fff com.apple.ApplicationServices (50.1 - 50.1) <86D6F10E-21F8-3CDC-9838-EB07A1C54BA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff3ab92000 - 0x7fff3abfdff7 com.apple.ApplicationServices.ATS (377 - 453.11) <4080F8BE-F2A2-3707-8754-436FBDB1DAF1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff3ac96000 - 0x7fff3adb5fff libFontParser.dylib (228.6) <BBCBEE2C-5B55-3278-B81D-22D72466753E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff3adb6000 - 0x7fff3ae01ff7 libFontRegistry.dylib (228.12.1.1) <B515718C-81BC-3705-A207-7215486C6D28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff3ae60000 - 0x7fff3ae93ff7 libTrueTypeScaler.dylib (228.6) <760BF895-3D7A-36E2-B97C-6775C3615A1D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib 0x7fff3aefd000 - 0x7fff3af01ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <4B1238CC-9B77-3AA5-8329-EE3C736F07EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy 0x7fff3af9e000 - 0x7fff3aff0ff3 com.apple.HIServices (1.22 - 627.14.2) <1F851BF9-AD29-3558-9EA5-AAD9BAAAC823> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff3aff1000 - 0x7fff3afffff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <5654723A-7B3B-391F-B9F7-0DE4D5940185> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff3b000000 - 0x7fff3b04cfff com.apple.print.framework.PrintCore (14.2 - 503.8) <F1246C9A-2216-3390-8DF1-89304F47CE5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff3b04d000 - 0x7fff3b088ff7 com.apple.QD (3.12 - 407.2) <F6B648DA-DA39-3EB4-B593-1B7E316661CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff3b089000 - 0x7fff3b095ff7 com.apple.speech.synthesis.framework (8.1.0 - 8.1.0) <CF19C8B6-AAD5-3DCF-ABD0-3BABB44D119C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff3b096000 - 0x7fff3b333fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <5D484151-F269-3D98-B507-0544A6B950AC> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff3b335000 - 0x7fff3b335fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <91100E0A-C14D-3E6C-B095-0C4109AC6694> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fff3b699000 - 0x7fff3ba5afff com.apple.CFNetwork (976 - 976) <A434842F-305B-301D-8F88-373CA7BF7196> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff3ba6f000 - 0x7fff3ba6ffff com.apple.Carbon (158 - 158) <82E18DC5-6557-3A66-89A9-9FAD7B4E56DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff3ba70000 - 0x7fff3ba73ffb com.apple.CommonPanels (1.2.6 - 98) <775C94BE-EC00-315F-96E0-F0C1CD6EE3F4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x7fff3ba74000 - 0x7fff3bd7bff7 com.apple.HIToolbox (2.1.1 - 917.3) <8FEBBC30-9C36-3AD4-BC4C-AE3537E8943D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff3bd7c000 - 0x7fff3bd7fffb com.apple.help (1.3.8 - 66) <0C6CC127-A860-30D2-8434-6CC3CAFFB030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x7fff3bd80000 - 0x7fff3bd85ff7 com.apple.ImageCapture (9.0 - 1530.1) <72ABBF32-531B-3B04-926D-E14B8D9003A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x7fff3bd86000 - 0x7fff3be1aff3 com.apple.ink.framework (10.9 - 225) <344AACCC-E997-3498-8B1D-2EFD3A889205> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fff3be1b000 - 0x7fff3be35fff com.apple.openscripting (1.7 - 179) <A57FC4DB-4C51-3ABB-842F-9578991043E3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fff3be56000 - 0x7fff3be57fff com.apple.print.framework.Print (14.2 - 267.4) <618D290C-2EA0-3959-A2A8-FB7B61DA92DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fff3be58000 - 0x7fff3be5aff7 com.apple.securityhi (9.0 - 55006) <2FE1EB07-F717-3E89-9662-8BA7C17C6AEC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x7fff3be5b000 - 0x7fff3be61ff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <F7E95C56-19E8-30A1-9594-84D4DD89F6D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff3bf8a000 - 0x7fff3bf8afff com.apple.Cocoa (6.11 - 23) <3F281295-3B16-359C-AE0C-5B4181DE1579> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff3bf98000 - 0x7fff3c064fff com.apple.ColorSync (4.13.0 - 3340) <2F45EB01-0C51-3D25-9836-18F99222E1C7> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff3c1ff000 - 0x7fff3c28ffff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E7EF105-B843-370D-884E-0A43E1A5800B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff3c2f5000 - 0x7fff3c320ff7 com.apple.CoreBluetooth (1.0 - 1) <F041753E-7709-3FA4-ADA3-6B37296D92FB> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x7fff3c321000 - 0x7fff3c6c2fef com.apple.CoreData (120 - 866.1) <18CD58FD-513E-385B-B43C-08EEB909709C> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff3c6c3000 - 0x7fff3c7acff7 com.apple.CoreDisplay (101.3 - 106.2) <EE0D334B-8B71-3A70-9F90-677171D6762F> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay 0x7fff3c7ad000 - 0x7fff3cbfafef com.apple.CoreFoundation (6.9 - 1562) <02A2C178-9FF6-385C-A9C5-7F4FC9D66311> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff3cbfc000 - 0x7fff3d289ff7 com.apple.CoreGraphics (2.0 - 1249.2) <78B75F62-4B60-3FF4-9259-8981E755F6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff3d28b000 - 0x7fff3d5b4fff com.apple.CoreImage (14.2.0 - 720.0.130) <B356BA95-EDD3-35D8-9E4B-250AF6C6DDF9> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fff3d905000 - 0x7fff3da06ff7 com.apple.CoreMedia (1.0 - 2285.4.4) <AC7E25F4-77B4-351E-974D-760F4F96FEDE> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia 0x7fff3da6a000 - 0x7fff3da6afff com.apple.CoreServices (941 - 941) <6DBA4791-26DB-39FB-A6A3-5910A0F2EDD2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff3da6b000 - 0x7fff3dae9ffb com.apple.AE (771 - 771) <4B009524-699E-3891-98DD-E3B6BB433C8F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff3daea000 - 0x7fff3ddc2ff7 com.apple.CoreServices.CarbonCore (1178.16 - 1178.16) <17FC2B9E-EB6C-3768-A2D0-6E086F2563D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff3ddc3000 - 0x7fff3de0dff7 com.apple.DictionaryServices (1.2 - 284.16.3) <1DAC9153-FB5A-3798-8797-CBFEFF227F71> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff3de0e000 - 0x7fff3de16ffb com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <8E1507EA-F0A8-3845-B32D-4FBC1381E89C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff3de17000 - 0x7fff3dfe2fff com.apple.LaunchServices (941 - 941) <A8E42760-995C-35E2-BF4A-C96FD0633B29> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff3dfe3000 - 0x7fff3e085fff com.apple.Metadata (10.7.0 - 1191.53) <48609998-8A34-3CAF-8A42-52C180809656> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff3e086000 - 0x7fff3e0d1ff7 com.apple.CoreServices.OSServices (941 - 941) <1B9EA259-09DF-332B-807A-BD50F3184CAC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff3e0d2000 - 0x7fff3e140ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <CEC29BB5-D28E-3424-84FE-70756E521F3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff3e141000 - 0x7fff3e165ffb com.apple.coreservices.SharedFileList (71.27 - 71.27) <6389B59D-DDAC-3C97-A982-137B9B1FB734> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fff3e4ad000 - 0x7fff3e612ffb com.apple.CoreText (352.0 - 584.26) <5F61037C-825D-37A4-9091-0047413CC213> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff3e613000 - 0x7fff3e650fff com.apple.CoreVideo (1.8 - 0.0) <34EC73F1-F0ED-32F5-B96E-7683B1F9A7A2> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff3e651000 - 0x7fff3e6e7ffb com.apple.framework.CoreWLAN (13.0 - 1370.8) <32426190-3455-3049-8C09-0EC04D9C1279> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x7fff3e964000 - 0x7fff3e969fff com.apple.DiskArbitration (2.7 - 2.7) <97707A79-30E7-3D99-AA20-B992B0900BC4> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff3eb2f000 - 0x7fff3eb31ff7 com.apple.ForceFeedback (1.0.6 - 1.0.6) <42A74696-FDA2-3F33-872A-A452D246B80C> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback 0x7fff3eb32000 - 0x7fff3ef00fff com.apple.Foundation (6.9 - 1562) <83D4A12B-EA5A-3C62-8D93-95E64F0A256B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff3ef71000 - 0x7fff3efa1ff3 com.apple.GSS (4.0 - 2.0) <86D07291-5DFC-30C2-9A18-5FCEDB0BE621> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff3f0bb000 - 0x7fff3f1c5ff3 com.apple.Bluetooth (6.0.10 - 6.0.10f1) <B3E7A841-1D1B-3043-A2C9-398928CB31AB> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x7fff3f227000 - 0x7fff3f2bafff com.apple.framework.IOKit (2.0.2 - 1483.240.1) <241690BB-8AFA-3B6A-A210-67874197CB59> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff3f2bc000 - 0x7fff3f2c6ff7 com.apple.IOSurface (255.1 - 255.1) <58826B1A-38E8-3C76-8FFC-76C9282DA893> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff3f31d000 - 0x7fff3f4bbfff com.apple.ImageIO.framework (3.3.0 - 1822.1) <908907D5-5C29-32F7-ACD9-C6A6D51C4D15> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff3f4bc000 - 0x7fff3f4c0ffb libGIF.dylib (1822.1) <35E37B95-1962-3A25-9C9E-CADD161152B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff3f4c1000 - 0x7fff3f5a6fe7 libJP2.dylib (1822.1) <BDBCBF28-12DB-3D63-B6F0-A559D1839F81> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff3f5a7000 - 0x7fff3f5ccff7 libJPEG.dylib (1822.1) <D443C754-4AFC-38E1-9E45-D309ACBCE17B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff3f89f000 - 0x7fff3f8c5fe7 libPng.dylib (1822.1) <28FE6E2C-1A17-3A84-AAF3-76014DEADDD4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff3f8c6000 - 0x7fff3f8c8ff7 libRadiance.dylib (1822.1) <687906E3-4EC2-3CE9-B7EA-34418239EE1B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff3f8c9000 - 0x7fff3f917ffb libTIFF.dylib (1822.1) <0A1C083B-CE2F-3A00-8E45-EB58DCA2FF34> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fff409c1000 - 0x7fff409dafff com.apple.Kerberos (3.0 - 1) <5D1B0593-3C0E-32D5-AAE5-ABC22A98B639> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff40c98000 - 0x7fff40ca2fff com.apple.MediaAccessibility (1.0 - 114.4) <C0584BAA-27BC-30F4-8B0C-5043559995AA> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility 0x7fff40d5c000 - 0x7fff413fafff com.apple.MediaToolbox (1.0 - 2285.4.4) <BAA7289A-FD04-30AD-B46E-89310BF67C02> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox 0x7fff413fc000 - 0x7fff4148ffff com.apple.Metal (158.5 - 158.5) <72BF7187-81FE-389B-882F-7B2587FEB455> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fff414ac000 - 0x7fff414ccff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <18281B14-0C6A-38F8-AB80-2D4BB0743C88> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore 0x7fff414cd000 - 0x7fff4154bff7 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <BEAF764B-362B-3C45-86F5-2AFBA5FA0F47> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage 0x7fff4154c000 - 0x7fff41574fff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <116D6C1A-2FD7-3743-95A0-CDDA3D459529> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix 0x7fff41575000 - 0x7fff416a7ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <88E80BEE-3D2B-328B-80D4-F4717BDB2E9F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork 0x7fff416a8000 - 0x7fff416c3ff7 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <E0E652B0-1624-3435-AD60-83A9C4B59852> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector 0x7fff416c4000 - 0x7fff416c4ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <1BBA8BC8-49C6-3C9B-B985-7CE4373E3553> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders 0x7fff428c2000 - 0x7fff428ceffb com.apple.NetFS (6.0 - 4.0) <918DF6CD-2DB0-36A8-B869-5EF637A06C0D> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff42c4d000 - 0x7fff42c72ff7 com.apple.audio.OpenAL (1.8 - 1.8) <A43E8D93-FBEE-3A59-A4E3-43B1FFC7BAC8> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL 0x7fff45385000 - 0x7fff4538dfe7 libcldcpuengine.dylib (2.10.3) <D7BF3AFE-3E48-35FF-B674-6CA33B982D63> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib 0x7fff4538e000 - 0x7fff453e6fff com.apple.opencl (2.15.1 - 2.15.1) <CC9439C3-FF30-38D2-BF2F-EA0EF1B5775E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff453e7000 - 0x7fff45403ff7 com.apple.CFOpenDirectory (10.14 - 207.200.4) <2CB1F122-2FA0-347C-8454-9CE0FA150832> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff45404000 - 0x7fff45410ffb com.apple.OpenDirectory (10.14 - 207.200.4) <A3FB0F0C-57F4-3F89-A4B1-63DA1F7C9E8E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff45d73000 - 0x7fff45d75fff libCVMSPluginSupport.dylib (17.3.1) <B2310175-04D6-378B-A220-A8AD7F0DA68E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff45d76000 - 0x7fff45d7bff3 libCoreFSCache.dylib (163.20) <566DB80E-F1D6-3AEC-AF06-08955507AFEE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fff45d7c000 - 0x7fff45d80fff libCoreVMClient.dylib (163.20) <B9A89373-BDCD-3003-9A82-6D73B930A122> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff45d81000 - 0x7fff45d89ffb libGFXShared.dylib (17.3.1) <9FFA679A-8CC9-3932-8A41-AA80C386AD3A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff45d8a000 - 0x7fff45d95fff libGL.dylib (17.3.1) <CFAB6AE4-E646-3E8A-B872-EF091CAF949E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff45d96000 - 0x7fff45dd0fef libGLImage.dylib (17.3.1) <1AEC8E56-D851-3516-96FE-2829883A8302> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff45dd1000 - 0x7fff45f43ff3 libGLProgrammability.dylib (17.3.1) <3B701B8D-FF2C-383E-8F94-77B052ECC075> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x7fff45f44000 - 0x7fff45f81fff libGLU.dylib (17.3.1) <90279918-D4B2-31E0-9709-8E06628D9486> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff46931000 - 0x7fff46940ff3 com.apple.opengl (17.3.1 - 17.3.1) <2F59064F-D6EF-35CD-9747-20A91DB3D5DF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff46941000 - 0x7fff46ad7ff7 GLEngine (17.3.1) <2320D7E8-11EF-3667-8FC9-7EA5ABD6B8AD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine 0x7fff46ad8000 - 0x7fff46b00ff7 GLRendererFloat (17.3.1) <444BAB14-2648-3CD9-863F-695EA9206059> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat 0x7fff4779c000 - 0x7fff479f5fff com.apple.QuartzCore (1.11 - 696.3) <01A2F065-8759-311D-AC2E-FD49F52A87FA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff48249000 - 0x7fff48571ff7 com.apple.security (7.0 - 58286.240.4) <91A03FF2-2EE9-36A7-AC4F-169E11FE7846> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff48572000 - 0x7fff48601fff com.apple.securityfoundation (6.0 - 55185.200.14) <F6A0EC77-51DB-3312-991C-3E1F920DE8F1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff48633000 - 0x7fff48637ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <26BA237C-DBA0-3322-B9BF-8B8E739E3A20> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff489f4000 - 0x7fff48a64ff3 com.apple.SystemConfiguration (1.17 - 1.17) <A8FD596E-C858-397F-836C-978038B97AC0> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff48cc5000 - 0x7fff49027fff com.apple.VideoToolbox (1.0 - 2285.4.4) <76B3A88C-9042-329D-8DD7-56AEE23D1790> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox 0x7fff4bcd2000 - 0x7fff4bd77fe7 com.apple.APFS (1.0 - 1) <BCB42C90-DEE0-3CD2-9B28-55CD8EFD9487> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS 0x7fff4c7c3000 - 0x7fff4c7c4ff3 com.apple.AggregateDictionary (1.0 - 1) <EBA6443E-6CF0-34F6-B77A-3FCEC57F8F80> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary 0x7fff4cdc1000 - 0x7fff4cdedff7 com.apple.framework.Apple80211 (13.0 - 1376.2) <A71EADCB-7582-3D1B-9122-356F03E11594> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x7fff4d0c9000 - 0x7fff4d0d8fcf com.apple.AppleFSCompression (96.200.3 - 1.0) <78D538DD-1D24-34FC-AFB3-10411494870D> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x7fff4d1d6000 - 0x7fff4d1e1fff com.apple.AppleIDAuthSupport (1.0 - 1) <E41452B2-3AFB-3493-BB82-0CE6D04DF424> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport 0x7fff4d222000 - 0x7fff4d26bff3 com.apple.AppleJPEG (1.0 - 1) <EC4C49F1-C060-3C0F-910F-3620985D4F12> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fff4d4be000 - 0x7fff4d4e6ff7 com.apple.applesauce (1.0 - ???) <58654BC0-9243-39D1-BC43-B7F2E37A3A44> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce 0x7fff4d5b1000 - 0x7fff4d601fff com.apple.AppleVAFramework (5.0.44 - 5.0.44) <618AB3FC-6A41-3A84-A305-CEA19434EB1C> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA 0x7fff4d64c000 - 0x7fff4d662ffb com.apple.AssertionServices (1.0 - 1) <3F767D20-FE14-35CF-A089-E0445375ECFB> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices 0x7fff4d99e000 - 0x7fff4dc41ff7 com.apple.AuthKit (1.0 - 1) <4FF8DA76-2250-39B9-B6A9-0E584C8B988F> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit 0x7fff4de12000 - 0x7fff4de1bff3 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <05CF66F0-9650-3F75-9857-F8D186043866> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement 0x7fff4de1c000 - 0x7fff4debefff com.apple.backup.framework (1.10.3 - ???) <0B4C2292-AEA9-39B5-A65F-8F381166C5C2> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fff4debf000 - 0x7fff4df30ffb com.apple.BaseBoard (360.24 - 360.24) <04AF4372-C5D3-3F0A-A688-68D888D6D138> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard 0x7fff4fae5000 - 0x7fff4faeefff com.apple.CommonAuth (4.0 - 2.0) <090893E5-BB65-39DA-A174-EAB2C7191EFE> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff4ffac000 - 0x7fff50383fef com.apple.CoreAUC (273.0.0 - 273.0.0) <FE2B4D86-2C83-3FE2-A427-54DA2170E980> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC 0x7fff50384000 - 0x7fff503b5fff com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <B15A24E4-2A92-3FD7-8F20-C372E4115FA7> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD 0x7fff507ff000 - 0x7fff50813fff com.apple.CoreEmoji (1.0 - 69.19.8) <26BC0F82-08C1-3EBD-9299-D3CC5091C467> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji 0x7fff50de9000 - 0x7fff50e5bff7 com.apple.CoreNLP (1.0 - 130.15.22) <D0A3E880-CDEA-360A-9838-220D76BAECC6> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP 0x7fff51126000 - 0x7fff5112effb com.apple.CorePhoneNumbers (1.0 - 1) <2D9AF545-ED3C-3EC1-887F-86922652EC57> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers 0x7fff512bd000 - 0x7fff512eefff com.apple.CoreServicesInternal (357 - 357) <789E57F4-5A14-3220-93DF-1D4FEE315431> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x7fff516c3000 - 0x7fff51751ff7 com.apple.CoreSymbolication (10.1 - 64460.6) <177AC44B-32E4-3F80-A36B-5B9999B388A8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff517e1000 - 0x7fff5190dfff com.apple.coreui (2.1 - 498.46) <5EFE2CDC-897C-3A6B-A60B-4E0FB1D1ECA9> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fff5190e000 - 0x7fff51a93fff com.apple.CoreUtils (5.7.4 - 574.17) <DEF9C8A6-DDF1-37F4-A7F0-7DFAA95E8451> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils 0x7fff51aea000 - 0x7fff51b4dffb com.apple.framework.CoreWiFi (13.0 - 1370.8) <818F8915-BA51-3145-9C40-C9B8D7BE2DBD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi 0x7fff51b4e000 - 0x7fff51b5fffb com.apple.CrashReporterSupport (10.13 - 938.23) <D8D105F5-B6FB-3E91-A116-7CD92171E5C5> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fff51be2000 - 0x7fff51bf1ff3 com.apple.framework.DFRFoundation (1.0 - 211) <B72944ED-E4E8-3479-B832-8D50C4E30386> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation 0x7fff51bf2000 - 0x7fff51bf6ff7 com.apple.DSExternalDisplay (3.1 - 380) <76449D22-BA27-3FB1-AD25-A290936E6DEA> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay 0x7fff51c79000 - 0x7fff51cf0ffb com.apple.datadetectorscore (7.0 - 590.24) <3A49EC90-2081-3031-8CAE-3A6D5F7BFA1E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x7fff51d3e000 - 0x7fff51d7ffff com.apple.DebugSymbols (185 - 185) <64F5F9D6-401D-388B-82AD-A48B56413556> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x7fff51d80000 - 0x7fff51ed9ff7 com.apple.desktopservices (1.13.1 - ???) <AD61A660-0218-327E-8963-A1A170EC2C20> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff52f1b000 - 0x7fff53343fff com.apple.vision.FaceCore (3.3.4 - 3.3.4) <41218EB7-19C9-3813-A793-B0623387CADF> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fff56c65000 - 0x7fff56c66fff libmetal_timestamp.dylib (902.2.2) <55E0B1F2-94F0-3A77-9DB3-152F44848DA5> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib 0x7fff58304000 - 0x7fff5830fff7 libGPUSupportMercury.dylib (17.3.1) <CBF68814-AF66-3B8D-AF60-69469EA92E61> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib 0x7fff58310000 - 0x7fff58315ff7 com.apple.GPUWrangler (3.28.4 - 3.28.4) <7E06C75D-5502-3F1D-987C-4F103917CD85> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler 0x7fff59180000 - 0x7fff5918ffff com.apple.GraphVisualizer (1.0 - 5) <CAFE626E-9738-3C14-88AA-B6A9182F2C39> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer 0x7fff592e0000 - 0x7fff59355fff com.apple.Heimdal (4.0 - 2.0) <D99FF31F-6310-3D80-8AE3-64934385AC11> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff5a73b000 - 0x7fff5a744fff com.apple.IOAccelMemoryInfo (1.0 - 1) <4C91E3B6-3BB3-3AB6-942C-F67CC0B21228> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo 0x7fff5a745000 - 0x7fff5a74cffb com.apple.IOAccelerator (404.2.2 - 404.2.2) <2F099589-DBE9-3442-AC93-F4AB363482A0> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fff5a750000 - 0x7fff5a769fff com.apple.IOPresentment (1.0 - 42.6) <F7E91CC9-E4BB-3904-8647-0473E3BCAF70> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment 0x7fff5ab7e000 - 0x7fff5abadff7 com.apple.IconServices (379 - 379) <694E17A6-471B-3C57-92D6-ECC4295FB859> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fff5ae4d000 - 0x7fff5ae60fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <DC6F5E18-3411-32AF-B395-AFC110C74A63> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle 0x7fff5ae7c000 - 0x7fff5af73fff com.apple.LanguageModeling (1.0 - 159.15.15) <34609F31-4DA1-3881-8947-85BEA7AFC938> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff5af74000 - 0x7fff5afb5ff7 com.apple.Lexicon-framework (1.0 - 33.15.10) <07E008F3-E823-333B-8B41-A46024AB0561> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon 0x7fff5afbc000 - 0x7fff5afc2ff7 com.apple.LinguisticData (1.0 - 238.23.4) <F6AA7095-3975-3C76-9833-BBE955EFEBD7> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData 0x7fff5b821000 - 0x7fff5b824fff com.apple.Mangrove (1.0 - 25) <8DF73279-BCEB-38CE-AE83-571C1B3FF45B> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove 0x7fff5bd1f000 - 0x7fff5bd47ffb com.apple.spotlight.metadata.utilities (1.0 - 1191.53) <2CFFD786-87A5-3629-B5E1-8E4DEF51ADA8> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities 0x7fff5bd48000 - 0x7fff5bddafff com.apple.gpusw.MetalTools (1.0 - 1) <C0489BBD-C25C-33E5-84CD-8A50205080A0> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools 0x7fff5bdef000 - 0x7fff5be08fff com.apple.MobileAssets (1.0 - 437.230.2) <D962A68E-00AC-3C2F-BC09-0C16E77FE85E> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset 0x7fff5bf85000 - 0x7fff5bfa0ff3 com.apple.MobileKeyBag (2.0 - 1.0) <663E513E-CE91-3474-9108-77DF844F17BA> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag 0x7fff5c02e000 - 0x7fff5c058ff7 com.apple.MultitouchSupport.framework (2410.5 - 2410.5) <3A712911-F672-3BB3-B62B-A2A7BADF3578> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff5c2cb000 - 0x7fff5c2d6fff com.apple.NetAuth (6.2 - 6.2) <A6474ABC-FD4B-3A8F-AB33-7AACEEED7F0E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff5cba3000 - 0x7fff5cbf9fff com.apple.OTSVG (1.0 - ???) <F020144A-D840-390D-A87F-29E8095C78AF> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG 0x7fff5dd64000 - 0x7fff5dd73ff3 com.apple.PerformanceAnalysis (1.217 - 217) <AA34989F-7E01-303E-8134-5BB37CE82DDF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fff5fd32000 - 0x7fff5fd50ff7 com.apple.ProtocolBuffer (1 - 263.1) <D70A1E3D-D2F7-3765-861C-173F5BBC848B> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer 0x7fff5feff000 - 0x7fff5ff57f0f com.apple.ROCKit (24 - 24) <FA6B086A-1841-3A5E-800B-CE7A52C3DAF1> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit 0x7fff6007b000 - 0x7fff6009effb com.apple.RemoteViewServices (2.0 - 128) <55D89BC9-0613-3910-B63E-9A146D35D91A> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fff61a14000 - 0x7fff61b32fff com.apple.Sharing (1214.19 - 1214.19) <27C2CFC8-1C1B-3F98-B0BC-7AB6B1847B1B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fff628ec000 - 0x7fff62b9eff3 com.apple.SkyLight (1.600.0 - 337.5) <B18B2F6F-F44B-3B5B-8DA1-3B8977E59240> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight 0x7fff6336f000 - 0x7fff6337cfff com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <FABB97BC-9555-33FE-B6C5-606CC403CE16> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0x7fff63a61000 - 0x7fff63aa0ff3 com.apple.StreamingZip (1.0 - 1) <251128E7-C343-3799-A31B-8B10CEC69F19> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip 0x7fff641dd000 - 0x7fff6426aff7 com.apple.Symbolication (10.1 - 64460.8) <7DDC5C90-947F-34FF-864D-5ED3C2B746A9> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x7fff64773000 - 0x7fff64780ffb com.apple.TCC (1.0 - 1) <81F88B91-49C1-36E7-8A39-C4BD654EE942> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff649f3000 - 0x7fff64abaff7 com.apple.TextureIO (3.8.4 - 3.8.1) <83CDF659-E5B3-381F-BDA1-FF0BFA17B5EE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO 0x7fff64b74000 - 0x7fff64b75fff com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <5C3E1B2D-40A8-3237-A8D9-4E7B15EEA678> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x7fff64b7b000 - 0x7fff64d35fff com.apple.UIFoundation (1.0 - 551) <65A80450-7A24-3366-B521-4D02C4DB5094> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation 0x7fff65a24000 - 0x7fff65b0dff7 com.apple.ViewBridge (401.1 - 401.1) <E76BC854-5B08-3FFF-AA2C-9679754FCAF0> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff66333000 - 0x7fff66336fff com.apple.dt.XCTTargetBootstrap (1.0 - 1) <5F779D77-4AB1-3CCD-9AAF-101EC7E4905B> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap 0x7fff66767000 - 0x7fff66769ff3 com.apple.loginsupport (1.0 - 1) <67BC49D6-320F-33ED-912E-16E5A342F385> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fff6676a000 - 0x7fff6677ffff com.apple.login (3.0 - 3.0) <D6486C5A-E644-3F43-AD27-5E14685CD8D6> /System/Library/PrivateFrameworks/login.framework/Versions/A/login 0x7fff66a24000 - 0x7fff66a5cfff libCRFSuite.dylib (41.15.4) <92752A96-D1CF-3CA1-837A-1E075AE4C642> /usr/lib/libCRFSuite.dylib 0x7fff66a5f000 - 0x7fff66a6aff7 libChineseTokenizer.dylib (28.15.3) <55572692-4918-3C54-AD35-726E03EC47D5> /usr/lib/libChineseTokenizer.dylib 0x7fff66afb000 - 0x7fff66afcff7 libDiagnosticMessagesClient.dylib (107) <15210AC0-61F9-3F9D-A159-A009F62EB537> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff66b33000 - 0x7fff66cf6ff7 libFosl_dynamic.dylib (18.3.2) <D67B74E9-EB95-38BC-995C-5F4CC044C3F7> /usr/lib/libFosl_dynamic.dylib 0x7fff66d4c000 - 0x7fff66d6bff7 libMobileGestalt.dylib (645.220.9) <C2C55511-993B-34D2-9040-902BFDA38141> /usr/lib/libMobileGestalt.dylib 0x7fff66d6c000 - 0x7fff66d6cfff libOpenScriptingUtil.dylib (179) <441A2E60-5D5C-3567-9B00-AA22E6EE5358> /usr/lib/libOpenScriptingUtil.dylib 0x7fff66ead000 - 0x7fff66eaeffb libSystem.B.dylib (1252.200.5) <C6201660-5E17-397D-BA21-C503420CD706> /usr/lib/libSystem.B.dylib 0x7fff66f38000 - 0x7fff66f39fff libThaiTokenizer.dylib (2.15.1) <F09EB0BB-1E8A-3391-BEF5-7D91F0715A62> /usr/lib/libThaiTokenizer.dylib 0x7fff66f4c000 - 0x7fff66f62ffb libapple_nghttp2.dylib (1.24.1) <71C126C5-D869-3E67-9778-058FA7F3CA74> /usr/lib/libapple_nghttp2.dylib 0x7fff66f63000 - 0x7fff66f8cffb libarchive.2.dylib (54.200.3) <32B8634D-E465-3F6D-B254-A20D44504508> /usr/lib/libarchive.2.dylib 0x7fff66f8d000 - 0x7fff6700cfef libate.dylib (1.13.8) <C7F1CEC4-467F-34B2-92FF-6482460A39E1> /usr/lib/libate.dylib 0x7fff67010000 - 0x7fff67010ff3 libauto.dylib (187) <003DEF68-0C59-3AFB-A7B7-A1B5ED301AF2> /usr/lib/libauto.dylib 0x7fff670e7000 - 0x7fff670f7ff3 libbsm.0.dylib (39.200.18) <58A9ACEC-BF46-3A4E-86F5-3DD9AD7095B4> /usr/lib/libbsm.0.dylib 0x7fff670f8000 - 0x7fff67106fff libbz2.1.0.dylib (38.200.3) <4DEC3797-087F-3C8D-815B-48E895813251> /usr/lib/libbz2.1.0.dylib 0x7fff67107000 - 0x7fff6715eff7 libc++.1.dylib (400.9.4) <B260AC33-EB9A-30C6-8746-D011B3B02B08> /usr/lib/libc++.1.dylib 0x7fff6715f000 - 0x7fff67174fff libc++abi.dylib (400.17) <446F4748-8A89-3D2E-AE1C-27EEBE93A8AB> /usr/lib/libc++abi.dylib 0x7fff67175000 - 0x7fff67175ff3 libcharset.1.dylib (51.200.6) <43F7E100-F5D1-36AB-A26E-CF94196A19C0> /usr/lib/libcharset.1.dylib 0x7fff67176000 - 0x7fff67186ffb libcmph.dylib (6.15.1) <CEDA6538-C071-3B5A-948E-DF61E2878983> /usr/lib/libcmph.dylib 0x7fff67187000 - 0x7fff6719fffb libcompression.dylib (52.200.13) <05A2A91B-D24D-39E8-A071-261CBC5BB158> /usr/lib/libcompression.dylib 0x7fff6744a000 - 0x7fff67460fff libcoretls.dylib (155.220.1) <1229F9EA-C070-3D03-9DC6-F548C59F9FD5> /usr/lib/libcoretls.dylib 0x7fff67461000 - 0x7fff67462ff3 libcoretls_cfhelpers.dylib (155.220.1) <33661841-3C3B-3608-86AC-C88D1CD6FE98> /usr/lib/libcoretls_cfhelpers.dylib 0x7fff67601000 - 0x7fff67791ffb libcrypto.35.dylib (22.240.1) <603427B4-6A5E-367B-B164-744606A2AA27> /usr/lib/libcrypto.35.dylib 0x7fff67ad9000 - 0x7fff67b30ffb libcups.2.dylib (462.10) <29B6D106-A5F2-321D-8916-90F595545D88> /usr/lib/libcups.2.dylib 0x7fff67c68000 - 0x7fff67c68fff libenergytrace.dylib (17.200.1) <F5BA8134-16F9-31CD-90E1-D1EBEBADA4AE> /usr/lib/libenergytrace.dylib 0x7fff67c9a000 - 0x7fff67c9fff7 libgermantok.dylib (17.15.2) <9381B152-5CFD-3D23-A5A7-4D64EE55B85E> /usr/lib/libgermantok.dylib 0x7fff67ca0000 - 0x7fff67ca5ff7 libheimdal-asn1.dylib (520.220.2) <D851A47D-E162-35F8-B8D4-6ABEA7FFDAD7> /usr/lib/libheimdal-asn1.dylib 0x7fff67cd1000 - 0x7fff67dc2ff7 libiconv.2.dylib (51.200.6) <9FB95807-7C62-32B7-A19F-946D7FB7CCA6> /usr/lib/libiconv.2.dylib 0x7fff67dc3000 - 0x7fff68026ffb libicucore.A.dylib (62109.0.1) <FEB89BD3-79C4-3208-A754-7E6BC4D38548> /usr/lib/libicucore.A.dylib 0x7fff68073000 - 0x7fff68074fff liblangid.dylib (128.15.1) <663D0A24-7260-31D1-9BFE-74D67B6F72F6> /usr/lib/liblangid.dylib 0x7fff68075000 - 0x7fff6808dfff liblzma.5.dylib (10.200.3) <9A52A949-0CB1-39B6-9244-D079FB609559> /usr/lib/liblzma.5.dylib 0x7fff680a5000 - 0x7fff68155fff libmecab.1.0.0.dylib (779.24.1) <590BC39C-2A3E-368B-9499-C808B84C4955> /usr/lib/libmecab.1.0.0.dylib 0x7fff68156000 - 0x7fff68393ff7 libmecabra.dylib (779.24.1) <22BFD5A8-EA42-3DC3-8910-F27DCFB1B631> /usr/lib/libmecabra.dylib 0x7fff68398000 - 0x7fff683c8ff7 libncurses.5.4.dylib (53.200.3) <2B715386-F391-3835-909F-A6DD86DCB4E3> /usr/lib/libncurses.5.4.dylib 0x7fff6856b000 - 0x7fff688c3ffb libnetwork.dylib (1229.240.1) <F99593DA-3089-3008-BE5B-5AC096EBF3A3> /usr/lib/libnetwork.dylib 0x7fff68955000 - 0x7fff690dbfe7 libobjc.A.dylib (750.1) <804715F4-F52D-34D0-8FEC-A25DC08513C3> /usr/lib/libobjc.A.dylib 0x7fff690ee000 - 0x7fff690f2ffb libpam.2.dylib (22.200.1) <85253002-89F2-3872-9C8A-1801303A2EBB> /usr/lib/libpam.2.dylib 0x7fff690f5000 - 0x7fff6912bff7 libpcap.A.dylib (79.200.4) <6D25197A-2F7C-3147-A45A-F6F13E55909F> /usr/lib/libpcap.A.dylib 0x7fff69245000 - 0x7fff6925dffb libresolv.9.dylib (65.200.2) <A1A77B4E-1AF0-3039-9945-D05440494E00> /usr/lib/libresolv.9.dylib 0x7fff692af000 - 0x7fff692b0ff7 libspindump.dylib (267.1) <9DEA015B-410E-3D6E-A3EE-54E046092EA9> /usr/lib/libspindump.dylib 0x7fff692b1000 - 0x7fff69488fe7 libsqlite3.dylib (274.22) <B30E3B7E-E22E-37A0-A3EB-EA333ADEE13E> /usr/lib/libsqlite3.dylib 0x7fff69715000 - 0x7fff69718ffb libutil.dylib (51.200.4) <10C5E165-0939-363A-9D13-7076F3B513EC> /usr/lib/libutil.dylib 0x7fff69719000 - 0x7fff69726fff libxar.1.dylib (404) <16E875B3-CF89-3059-87BB-36D301B32E7B> /usr/lib/libxar.1.dylib 0x7fff6972b000 - 0x7fff6980efff libxml2.2.dylib (32.8) <3E7875AC-3195-3800-AC48-8AA3B7BE51E4> /usr/lib/libxml2.2.dylib 0x7fff6980f000 - 0x7fff69837ff3 libxslt.1.dylib (16.1) <D6EBFEBB-F88E-398F-B1B5-66F413C2CD32> /usr/lib/libxslt.1.dylib 0x7fff69838000 - 0x7fff6984affb libz.1.dylib (70.200.4) <15F7B40A-424C-33BB-BF2C-7E8195128B78> /usr/lib/libz.1.dylib 0x7fff698bb000 - 0x7fff698bfff3 libcache.dylib (81) <704331AC-E43D-343A-8C24-39201142AF27> /usr/lib/system/libcache.dylib 0x7fff698c0000 - 0x7fff698caff3 libcommonCrypto.dylib (60118.220.1) <9C865644-EE9A-3662-AB77-7C8A5E561784> /usr/lib/system/libcommonCrypto.dylib 0x7fff698cb000 - 0x7fff698d2fff libcompiler_rt.dylib (63.4) <817772E3-E836-3FFD-A39B-BDCD1C357221> /usr/lib/system/libcompiler_rt.dylib 0x7fff698d3000 - 0x7fff698dcff3 libcopyfile.dylib (146.200.3) <5C5C4F35-DAB7-3CF1-940F-F47192AB8289> /usr/lib/system/libcopyfile.dylib 0x7fff698dd000 - 0x7fff69961fdf libcorecrypto.dylib (602.230.1) <C78D1A87-5543-3561-BEB4-3B480BA94ECB> /usr/lib/system/libcorecrypto.dylib 0x7fff699e8000 - 0x7fff69a22ff7 libdispatch.dylib (1008.220.2) <2FDB1401-5119-3DF0-91F5-F4E105F00CD7> /usr/lib/system/libdispatch.dylib 0x7fff69a23000 - 0x7fff69a52ff3 libdyld.dylib (655.1) <90C801E7-5D05-37A8-810C-B58E8C53953A> /usr/lib/system/libdyld.dylib 0x7fff69a53000 - 0x7fff69a53ffb libkeymgr.dylib (30) <A4EFD9A4-2EF3-3E18-B325-F527E3821939> /usr/lib/system/libkeymgr.dylib 0x7fff69a54000 - 0x7fff69a60ff7 libkxld.dylib (4903.241.1) <D039B38D-E8E6-3011-94F5-A21CD3D59526> /usr/lib/system/libkxld.dylib 0x7fff69a61000 - 0x7fff69a61ff7 liblaunch.dylib (1336.240.2) <D5F0014D-CF46-3B04-9DE0-A1466DA14A2C> /usr/lib/system/liblaunch.dylib 0x7fff69a62000 - 0x7fff69a67fff libmacho.dylib (921) <6ADB99F3-D142-3A0A-B3CE-031354766ACC> /usr/lib/system/libmacho.dylib 0x7fff69a68000 - 0x7fff69a6affb libquarantine.dylib (86.220.1) <58524FD7-63C5-38E0-9D90-845A79551C14> /usr/lib/system/libquarantine.dylib 0x7fff69a6b000 - 0x7fff69a6cff3 libremovefile.dylib (45.200.2) <BA53CA8A-9974-3A43-9265-B110B1AE470F> /usr/lib/system/libremovefile.dylib 0x7fff69a6d000 - 0x7fff69a84ff3 libsystem_asl.dylib (356.200.4) <33C62769-1242-3BC1-9459-13CBCDECC7FE> /usr/lib/system/libsystem_asl.dylib 0x7fff69a85000 - 0x7fff69a85fff libsystem_blocks.dylib (73) <152EDADF-7D94-35F2-89B7-E66DCD945BBA> /usr/lib/system/libsystem_blocks.dylib 0x7fff69a86000 - 0x7fff69b0efff libsystem_c.dylib (1272.200.26) <D6C701A2-9F17-308D-B6AC-9E17EF31B7DF> /usr/lib/system/libsystem_c.dylib 0x7fff69b0f000 - 0x7fff69b12ff7 libsystem_configuration.dylib (963.200.27) <94898525-ECC8-3CC9-B312-CBEAAC305E32> /usr/lib/system/libsystem_configuration.dylib 0x7fff69b13000 - 0x7fff69b16ff7 libsystem_coreservices.dylib (66) <10818C17-70E1-328E-A3E3-C3EB81AEC590> /usr/lib/system/libsystem_coreservices.dylib 0x7fff69b17000 - 0x7fff69b1dffb libsystem_darwin.dylib (1272.200.26) <07468CF7-982F-37C4-83D0-D5E602A683AA> /usr/lib/system/libsystem_darwin.dylib 0x7fff69b1e000 - 0x7fff69b24ff7 libsystem_dnssd.dylib (878.240.1) <5FEA5E1E-E80F-3616-AD33-8E936D61F31A> /usr/lib/system/libsystem_dnssd.dylib 0x7fff69b25000 - 0x7fff69b71ff3 libsystem_info.dylib (517.200.9) <54B65F21-2E93-3579-9B72-6637A03245D9> /usr/lib/system/libsystem_info.dylib 0x7fff69b72000 - 0x7fff69b9aff7 libsystem_kernel.dylib (4903.241.1) <CA10BC3A-5B09-32CE-B74F-BAD01755AA37> /usr/lib/system/libsystem_kernel.dylib 0x7fff69b9b000 - 0x7fff69be6ff7 libsystem_m.dylib (3158.200.7) <AF25F8E8-194C-314F-A2D3-A424853EE796> /usr/lib/system/libsystem_m.dylib 0x7fff69be7000 - 0x7fff69c0bff7 libsystem_malloc.dylib (166.220.1) <4777DC06-F9C6-356E-82AB-86A1C6D62F3A> /usr/lib/system/libsystem_malloc.dylib 0x7fff69c0c000 - 0x7fff69c17ff3 libsystem_networkextension.dylib (767.240.1) <4DB0D4A2-83E7-3638-AAA0-39CECD5C25F8> /usr/lib/system/libsystem_networkextension.dylib 0x7fff69c18000 - 0x7fff69c1ffff libsystem_notify.dylib (172.200.21) <65B3061D-41D7-3485-B217-A861E05AD50B> /usr/lib/system/libsystem_notify.dylib 0x7fff69c20000 - 0x7fff69c29fef libsystem_platform.dylib (177.200.16) <83DED753-51EC-3B8C-A98D-883A5184086B> /usr/lib/system/libsystem_platform.dylib 0x7fff69c2a000 - 0x7fff69c34fff libsystem_pthread.dylib (330.230.1) <80CC5992-823E-327E-BB6E-9D4568B84161> /usr/lib/system/libsystem_pthread.dylib 0x7fff69c35000 - 0x7fff69c38ff7 libsystem_sandbox.dylib (851.230.3) <D6469A17-C13C-3538-A300-D6517BB7F249> /usr/lib/system/libsystem_sandbox.dylib 0x7fff69c39000 - 0x7fff69c3bff3 libsystem_secinit.dylib (30.220.1) <5964B6D2-19D4-3CF9-BDBC-4EB1D42348F1> /usr/lib/system/libsystem_secinit.dylib 0x7fff69c3c000 - 0x7fff69c43ff7 libsystem_symptoms.dylib (820.237.2) <487E1794-4C6E-3B1B-9C55-95B1A5FF9B90> /usr/lib/system/libsystem_symptoms.dylib 0x7fff69c44000 - 0x7fff69c59ff7 libsystem_trace.dylib (906.220.1) <4D4BA88A-FA32-379D-8860-33838723B35F> /usr/lib/system/libsystem_trace.dylib 0x7fff69c5b000 - 0x7fff69c60ffb libunwind.dylib (35.4) <EF1A77FD-A86B-39F5-ABEA-6100AB23583A> /usr/lib/system/libunwind.dylib 0x7fff69c61000 - 0x7fff69c91fff libxpc.dylib (1336.240.2) <EE0CDA53-6FF9-3B4E-A571-335A5FF6B6F4> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process: task_for_pid: 117 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 38948 thread_create: 0 thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=556.2M resident=0K(0%) swapped_out_or_unallocated=556.2M(100%)
Writable regions: Total=4.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 384K 3
Activity Tracing 256K 2
CG backing stores 2100K 6
CG image 392K 21
CoreAnimation 136K 17
CoreGraphics 8K 2
CoreImage 48K 9
CoreUI image data 1084K 21
CoreUI image file 516K 6
Foundation 4K 2
Image IO 256K 2
Kernel Alloc Once 8K 2
MALLOC 4.3G 410
MALLOC guard page 32K 8
MALLOC_LARGE (reserved) 256K 2 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 256.0M 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
Memory Tag 249 156K 2
OpenGL GLSL 256K 4
STACK GUARD 56.1M 25
Stack 24.2M 26
VM_ALLOCATE 224.5M 509
DATA 61.7M 318
FONT_DATA 4K 2
GLSLBUILTINS 5176K 2
LINKEDIT 246.7M 54
TEXT 309.5M 312
UNICODE 564K 2
mapped file 59.5M 26
shared memory 756K 14
TOTAL 5.5G 1783
TOTAL, minus reserved VM space 5.3G 1783
