Page Menu
Home
Search
Configure Global Search
Log In
Create Task
Maniphest
T61459
Cycles OpenCL: Reduce compilation times (parent task)
Closed, Resolved
Public
TO DO
Actions
Edit Task
Edit Related Tasks...
Create Subtask
Edit Parent Tasks
Edit Subtasks
Merge Duplicates In
Close As Duplicate
Edit Related Objects...
Edit Commits
Edit Mocks
Edit Revisions
Subscribe
Mute Notifications
Award Token
Jeroen Bakker (jbakker)
Feb 12 2019, 1:56 PM
(Backlog)
Parent task for Cycles OpenCL compilation times project.
Related Objects
Search...
Task Graph
Subtype
Assigned
Task
TO DO
T61459
TO DO
T61461
Cycles OpenCL: Research per node compilation time
TO DO
T61661
Cycles OpenCL: Phase 1 - reducing compilation time
TO DO
T61463
Cycles OpenCL: Split bake functions in their own program.
TO DO
T61514
Cycles OpenCL: Revert use single kernel patch and test on windows
TO DO
T61576
Cycles OpenCL: Do not compile kernels that are not needed
TO DO
T61465
Cycles OpenCL: Optimize Voronoi Texture Node
TO DO
T61479
Cycles OpenCL: Optimize PointDensityTextureNode
TO DO
T61466
Cycles OpenCL: Merge small serial kernels
TO DO
T61513
Cycles OpenCL: split `primitive_attribute_float?` into `primitive_surface_attribute_float?` and `primitive_volume_attribute_float?`
TO DO
T61533
Cycles OpenCL: Refactor svm_attribute
TO DO
T61501
Cycles OpenCL: Reduce Kernel Recompilation
TO DO
T61736
Cycles OpenCL: Remove Mega kernel
TO DO
Thomas Dinges (dingto)
T61464
Cycles OpenCL: Merge shadow blocked kernels
TO DO
T61700
Cycles OpenCL: When baking the kernels seems to be compiled twice
TO DO
T61751
Cycles OpenCL: Test impact of features based on the render times.
DESIGN
T62252
Cycles OpenCL: Proposal Select better base features to reduce recompilation
TO DO
T62265
Cycles OpenCL: Remove `NODE_GROUP_ *` it is not used by any platform
TO DO
T62266
Cycles OpenCL: Change the minimum required features
T62267
Cycles OpenCL: Remove Single Program as it is not used by any platform
TO DO
T62304
Cycles OpenCL: Reduce Compilation times Subsurface when Volumetrics is enabled
TO DO
T61662
Cycles OpenCL: Phase 2 - User Experience
TO DO
T61752
Cycles OpenCL: Background Compilation of Kernels during BVH building
TO DO
T62300
Cycles OpenCL: Minimizing UX blocking during light baking
TO DO
T62301
Cycles OpenCL: Minimizing UX blocking during mesh displacement
TO DO
None
T62540
Cycles OpenCL: Precopile Kernels Used During Foreground Rendering
TO DO
T61663
Cycles OpenCL: Research using Spir(-V) kernels
TO DO
T61971
Cycles OpenCL: Make displace/background kernels optional
TO DO
T62533
Cycles OpenCL: What is the current state of Mesa AMD OpenCL?
lowered the priority of this task from
90
to
created this task.
renamed this task from
to
Feb 12 2019, 2:05 PM
to
Feb 12 2019, 8:08 PM
changed the status of subtask
T61461: Cycles OpenCL: Research per node compilation time
from
Unknown Status
to
Feb 15 2019, 1:38 PM
removed subtasks:
T61576: Cycles OpenCL: Do not compile kernels that are not needed
T61533: Cycles OpenCL: Refactor svm_attribute
T61514: Cycles OpenCL: Revert use single kernel patch and test on windows
T61513: Cycles OpenCL: split `primitive_attribute_float?` into `primitive_surface_attribute_float?` and `primitive_volume_attribute_float?`
T61501: Cycles OpenCL: Reduce Kernel Recompilation
T61479: Cycles OpenCL: Optimize PointDensityTextureNode
T61466: Cycles OpenCL: Merge small serial kernels
T61465: Cycles OpenCL: Optimize Voronoi Texture Node
T61464: Cycles OpenCL: Merge shadow blocked kernels
T61463: Cycles OpenCL: Split bake functions in their own program.
Feb 18 2019, 11:32 AM
T61736: Cycles OpenCL: Remove Mega kernel
from
Unknown Status
to
Feb 20 2019, 3:23 PM
T61971: Cycles OpenCL: Make displace/background kernels optional
from
Unknown Status
to
Feb 26 2019, 3:46 PM
T61663: Cycles OpenCL: Research using Spir(-V) kernels
from
Unknown Status
to
Mar 7 2019, 11:02 AM
changed the task status from
Unknown Status
to
Mar 20 2019, 2:32 PM
T61662: Cycles OpenCL: Phase 2 - User Experience
from
Unknown Status
to
T61661: Cycles OpenCL: Phase 1 - reducing compilation time
from
Unknown Status
to
T62533: Cycles OpenCL: What is the current state of Mesa AMD OpenCL?
from
Unknown Status
to
May 25 2019, 9:43 AM
Log In to Comment
