Radius in place of Size at Empty viewport menu
Confirmed, NormalPublicTO DO
I{F6596506}
am new to blender and not know where to post this but plz check it.It seem wrong to me
thanks
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Archived.Feb 13 2019, 9:59 AM
Sebastian Parborg (zeddb) claimed this task.
This not a bug.
You are adjusting the radius of the empty with that setting.
There is a mismatch in naming the same parameter in different places. Adjust Last Operator (radius) vs. Properties editor (size).
This was already changed for spheres T57718 [in a way it is the other way around there -- was changed from size to radius]
@William Reynish (billreynish): should we add this to papercuts T56950?
maybe @Zachman wants to have a go at this as well?
Philipp Oeser (lichtwerk) changed the task status from Archived to Unknown Status.Feb 13 2019, 10:40 AM
Philipp Oeser (lichtwerk) removed Sebastian Parborg (zeddb) as the assignee of this task.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.
Yeah I'll fix it. While I'm at it, I'll check other object types to see if there are similar discrepancies and fix those too
So @Brecht Van Lommel (brecht), just a question on this implementation. From what I can see, it wouldn't make sense to make all the empty types strictly radius or size. For example, radius makes sense for the circle or the single arrow, but not for the cube or the image. In the operator execute function it would be easy to add a condition based on the type to switch between a size and radius property, but that would require two properties on the operator, which is confusing. Would there be a way to control which property shows on the operator? Or is there another solution I'm not thinking of.
You can hide/show different properties in the UI with a custom operator draw functions.
But just rename it to size always, making it different depending on the type is not that helpful.
