2.80 beta Zooming and Scale and Few Other Issues
Operating system: Mac OS 10.13.6
Graphics card: AMD FirePro D700 6144 MB
Broken:
2.80 beta 2019-02-15
-I have an incremental mouse scroll wheel, does not zoom in slowly when close up on object. Have to press ctl+mmb to zoom when close to an object. Also not seeing a way to customize to fix in preferences.
-Object jumps to different zoom sizes when cycling from orthographic front, top, right, etc views to rotating with mouse view.
-Imported 3D objects come in much larger than say Rigify armatures/other default objects. Smaller objects are impossible to navigate with the above zooming problem.
-Updated shaders do not load and will randomly (sometimes after restarting) pop in and then will be fine. then will not update again when I make a shader change, say for example, to the normal map.
Is there a shortcut key list with just the top 50 or used shortcut keys? Like Mark Seam, Smooth, etc?
See above
Related Objects
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.Feb 18 2019, 11:31 PM
Closing since this is not a proper bug report.
