Mac OSX Power PC - Object Propeties problem
Closed, ResolvedPublicKNOWN ISSUE
Whenever I create a new object it only gives me the properties of that new object even when I select a
new object. This doesn't happen on my WinXP Computer. This makes it very difficult to make models.
Revisions and Commits
Logged In: YES
user_id=177
The information you gave isn't enough to precisely replicate the problem. Can you describe in detail the exact steps you took, so we can try and reproduce the problem?
thanks
Logged In: YES
user_id=5793
On a Mac OSX Power PC do t he following:
- Start Blender with a new file
- Create a new object such as a camera or cube.
- Try to select another object and it will not return that objects properties(in the buttons window), it will only return the object you have just created's properties.
Logged In: YES
user_id=5793
On a Mac OSX Power PC do the following:
Logged In: YES
user_id=146
I still can't redo this with that description (also running Mac OS X PPC).
- Is this a redraw/refresh problem, does it show ok after you do something in the buttons window?
- How do you select the object, 3d view or outliner, clicking or box select, .. ? Does that make any difference?
Logged In: YES
user_id=5793
I've attached a screen shot showing the problem. I clearly have the camera selected in the picture but
it only show the cubes properties.
Logged In: YES
user_id=177
There's nothing attached.
Logged In: YES
user_id=103
This is clearly an opengl problem. Anthoni: what kind of graphics is in your mac? Give all system specs, and can you check for available OSX upgrades?
(I only know nvidia had this once, a long time ago...)
Logged In: YES
user_id=5793
I can't seem to find out the spec except for processor and ram which is 1.0GHz and 256Mb and this is a power PC. I was just developing thing in my spare time at school. The previous versions had worked on this same computer.
Logged In: YES
user_id=5793
Logged In: YES
user_id=103
Leftmost top menu, "About this Mac" -> "More info"
Logged In: YES
user_id=5793
The More Info Button isn't working. I clicked it but it goes nowhere.
Logged In: YES
user_id=5793
I've been able to get around the problem by using the outline menu.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:37 AM
Diffusion changed the task status from Unknown Status to Resolved.Sep 30 2014, 10:44 AM
Closed by commit rP11f6b01428d4.
